20 Most Recent Jeep 10 x 20 Questions & Answers
97 jeep wrangler overheated due to bad water pump.
when you got it hot you probly blew a head gasket or worse worped/cracked the head. on mt caamaro i got wateer on the coil packs when changed water pump and they went out
6/22/2023 5:11:41 PM • Jeep 10 x 20 • Answered on Jun 22, 2023
2001 grand cherokee does not change from defrost to dash or floor although heat is hot any suggestions
First off I would like to appologize for this rediculously long post. I just know that, for me atleast, it is a little irritating when people give like one line solutions. I prefer ones that explain what things are, making it so I don't have to do more research to find out what/where something is or where it is located.
I had a similar problem on my 96 jeep grand Cherokee. Whenever I switched the setting to blow from the floor, it would come out of the dash. It would however switch from defrost to the vents. After I removed my dash to find the problem, I noticed that there was a vacuum hose (looks like a really thick wire with clear plastic L-shaped joints on the end) that is supposed to lead to the mechanism that changes the air flow from floor to vent or vent to defrost (looks like a small metallic cylinder that is a little smaller than a can of soda)(im not sure about an '01, but on my '96, that canister is located just above the accelerator pedal, and you can find this without removing your dash). That hose however wasn't connected to anything. Once I plugged it back in, my heater would switch from floor to vent to defrost like it was new.
So with your problem, you could possibly have your two hoses, that lead from the back of your switch that changes the flow of the air, disconnected or missing altogether. Another possible cause could be that your vaccuum storage container (located under the hood on the passenger side) isn't connected to that same switch. It could also have a leak in the hose or the storage container itself (unlikely that it leaks from the conainer due to its strength, unless it is under your battery and the battery leaked acid on it). This means that your jeep's vacuum system wouldn't have enough force to switch from the default setting, which is defrost, to your vents or floor. But it is actually quite common for your vacuum hose, that connects directly to the container to, over time, either break or disconnect from the storage container. A good way to check if you have a major leak in your main vacuum line is to see use your cruise control. If your cruise control completely doesn't work, then your line probably has a major leak or it isn't connected somewhere.
I will give you a forewarning, that if you take your dash apart, it will be a bit time consuming, so make sure that you don't have to drive anywhere for a while (possibly the rest of the day depending on your experience). I will also warn you that you will want to be careful when working under your dash. Most things will be fine, but the small vacuum lines that I mentioned earlier, you will want to be sure you don't cut them or pinch them when putting your dash back together (not too easy to do, but possible since they just look like thick wires). Also I wouldn't recommend that you take apart the main air ducts on the passenger side. It is very tricky to remove and is kind of easy to break it or knock a hole in it (the smaller ducts that lead to your dash/ vents are a lot easier to work with and are stronger). I bought the interior of a jeep and I tore through the dash, and I ended up busting a hole in that duct.
I hope this helps and the best of luck to you.
11/29/2012 5:11:37 PM • Jeep 10 x 20 • Answered on Nov 29, 2012
99 jeep cherokee not getting any heat. New
With engine cold, remove radiator cap, start engine, if there is air in the coolant system it will "burp" it out through the open radiator cap. Check fluid level and replace cap.
Good luck
1/24/2011 10:36:40 PM • Jeep 10 x 20 • Answered on Jan 24, 2011
My 1998 jeep grand cherokee only blows luke warm
If the blend door is allowing hot air to go from the heater core to the interior, then the heater core is likely to be clogged. Flush or replace the heater core that is clogged.
1/21/2011 6:28:21 AM • Jeep 10 x 20 • Answered on Jan 21, 2011
I have an electrical shortage in my car when i go
Try looking at the electrical entry socket into the heater motor, they are usually on the passanger side footwell and can be dislodged by the passangers feet hitting the underside of the motor casing !
4/2/2010 10:39:06 AM • Jeep 10 x 20 • Answered on Apr 02, 2010
2answers
Heat comes out driverside/cool air comes out the passenger side?
It sounds like your blend doors are broken. As it turns out, this is a VERY common problem with grand cherokees. My father and I fixed this problem on my 2001 Jeep Grand Cherokee Limited 4.7 about 2 months ago using a product called Heater Treater, found here: http://www.heatertreater.net/
You can find a very helpful detailed write-up of the fix/installation here: http://www.jeepsunlimited.com/forums/showthread.php?t=854246
Trust me, this REALLY works and a lot of Jeep Grand Cherokee owners, including myself, have done this. YOU WON'T HAVE TO REMOVE YOUR DASHBOARD, as the repair is done by simply removing your glove box. The downside is that you will lose Dual Climate Control, as the driver side thermostat will now control both sides. For me, it was worth it. Only spending about $150 for a Do-It-Yourself solution, versus spending about $1000 to have a mechanic remove my dashboard to fix it.
12/3/2009 3:26:22 AM • Jeep 10 x 20 • Answered on Dec 03, 2009
No Heat in 1990 Jeep Cherokee
well the first thing i would suggest is you take a look at its thermostat that could be over regulating hot air from flowing tothe heater if thats not got any major effect then have you been using an anti freeze formula for your engin coolant , because if not then it means the hot water pipes to your heater are blocked thank you.... if this was to benefit to you pease return the favour with a posetive rating
7/21/2009 11:30:55 PM • Jeep 10 x 20 • Answered on Jul 21, 2009
97 Jeep Wrangler/heating system
Putting a/c is way rediculously too costly to even attempt, also, jeep a/c back in the day was mediocre at best, just deal with it. If you wanna cap that hose line off, go to town, but id really suggest not turning on the fan (that does not blow clod air to begin with) and just putting your windows down.
7/7/2009 9:54:39 PM • Jeep 10 x 20 • Answered on Jul 07, 2009
02' LIBERTY BLOWER MOTOTR COMES ON WHEN IT WANTS TO.
Sound like a weak blower motor to me
5/23/2009 4:03:06 PM • Jeep 10 x 20 • Answered on May 23, 2009
1982 Jeep Cherokee no heat
if you can hear the motor(fan) spinning, check the linkage that controls which vents are open, also check for a vacuum leak as the vacuum hoses on a jeep that old go out frequently and many times control the switching for the heater/defrost/ac. your first thing to do will be to grab a manual for this jeep and check the actual location of the heater/vent/ac fan. there is always the chance that the fan slipped off the motor (usually doesn't happen, but the circlips have been known to fail)
have you tried it in any other position? ie: vent or ac
3/17/2009 8:35:32 PM • Jeep 10 x 20 • Answered on Mar 17, 2009
2answers
LIMITED HOT AIR IN HEATING
i have the same problem with a 1997 jeep cherokee country
1/26/2009 2:49:17 PM • Jeep 10 x 20 • Answered on Jan 26, 2009
1994 Jeep Cherokee
Check your alternator
12/17/2008 12:44:58 PM • Jeep 10 x 20 • Answered on Dec 17, 2008
Heating problem with my jeep
it sound like your blend door is not closing all the way and you may need to replace the door or the motor or may just need some wd40
12/3/2008 5:04:20 PM • Jeep 10 x 20 • Answered on Dec 03, 2008
2answers
94 jeep cherokee manual clutch fluid tube
easist fix is to visit a car junkyard and find a 94 jeep cherokee (or close to same year). remove the tube and pay the junkyard dog on the way out. Chances are the tube in the junkyard may also be developing a hole, so carefully inspect it before settling. Many tubes on cars today are metal that are covered in plastic. To remove it, keep in mind that it was installed at the factory, so removal is just the reversal. Look for a swivel connector at one end of tube (or both ends). This swivel connector is identified by a hexagonal "nut" and a "break" immediately next to it. This is actually a compression fitting that when tightened, forces two metal surfaces against each other that are tapered inside (look for this taper once removed). Now using an open-ended wrench, turn the nut loose while holding back rotation on the tube.
10/22/2008 5:32:38 PM • Jeep 10 x 20 • Answered on Oct 22, 2008
Serial numbers?
May I call you? or you can call me at 314-691-0812; Bob.
The spindle,(I believe) is what I need,but can't find exact part to buy in catalogs. I need the part #, or something to be able to buy trans. filter and gasket. If that helps.
4/27/2008 6:21:48 PM • Jeep 10 x 20 • Answered on Apr 27, 2008
1992 jeep cherokee
You gotta be specific. coulda be fouled plugs, tranny, coil.
3/22/2008 9:16:34 PM • Jeep 10 x 20 • Answered on Mar 22, 2008
92 Jeep Limited
Just out of curiosity. Is your Jeep an automatic or straight drive?
2/16/2008 8:43:21 PM • Jeep 10 x 20 • Answered on Feb 16, 2008
Engine replacement
look at engin makes from , dodge and cvhrysler but i would suggest you look for the chrysler voyeger lx model engin since they are simmilar in engin capacity . if that doesnt work out try converting a similar chgeaper engin , i know it sounds complicated but its really easy i did it on my vw golf , its all about the gearbox joining the engin and getting the engin moutains in place thats where the challenge is other than that its easy and convinient ...... thank you please return the favour
11/29/2007 5:51:50 PM • Jeep 10 x 20 • Answered on Nov 29, 2007
1992 jeep cherokee
this is quit normal in an old cars electrical wiring , there could be a short circuit in the wiring wich could be caused by a bunch of tied together wires hat have melted and are noe bonded together . which inturn causes your fuses to blow every time you plug them in ............ thank you
11/29/2007 5:41:27 PM • Jeep 10 x 20 • Answered on Nov 29, 2007
Jeep 10 x 20 Logo
23 questions posted
Top Jeep Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Jeep Optic Expert? Answer questions, earn points and help others
View Most Popular
Jeep Optics
  • Jeep Optics
Most Popular Question
limited hot air in heating
  • Optics
