20 Most Recent Jeep KNG36-JXLWBC AM/FM/Weather Radio Questions & Answers
tip
Safety
SAFETY
1. HANDLE WITH CARE AND AVOID CONTACT WITH CORROSIVE LIQUIDS.
2. AVOID LEAVING YOUR UNIT IN DIRECT SUNLIGHT OR IN HOT, HUMID OR DUSTY PL.ACFS
3. KEEP YOUR UNIT AWAY FROM HEATING APPLIANCES AND SOURCES OF ELECTRICAL NOISE SUCH AS FLUORESCENT LAMPS OR MOTORS.
4. ALWAYS TURN YOUR RADIO OR LANTERN OFF WHEN NOT IN USE AND REMOVE BATTERIES IF YOUR UNIT IS NOT GOING TO BE USED FOR LONG PERIOD.
5. OLD BATTERIES CAN LEAK AND CAUSE CORROSION DAMAGING YOUR UNIT.
6. LAMP BULBS OR LANTERN SHOULD ONLY BE REPLACED BY QUALIFIED TECHNICIAN.
NOTE: OUTPUT POWER: FM-550 mw,
AM-405mw
tip
Using the Compass
USING THE COMPASS
WHEN THE COMPASS (4) IS HORIZONTALLY PARALLEL, THE COMPASS (4) WILL
ADJUST THE DIRECTION AUTOMATICALLY. WHEN IT IS STABLIZED, IT WILL
INDICATE THE FOUR DIRECTIONS.
tip
Setting the Date and Time
SETTING THE DATE AND TIME
1. PRESS MODE (8) TWICE TO SET THE MONTH. PRESS SET (9) TO ADJUST THE DESIRED MONTH.
2. PRESS MODE (8) ONCE AGAIN TO SET THIS DATE. PRESS SET (9) TO ADJUST THE DESIRED DATE.
3. PRESS MODE (8) ONCE AGAIN TO SET THE HOUR. PRESS SET (9) TO ADJUST THE DESIRED HOUR.
4. PRESS MODE (8) ONCE AGAIN TO SET THE MINUTE. PRESS SET (9) TO ADJUST THE DESIRED MINUTE.
5. PRESS MODE (8) ONCE AGAIN TO RETURN TO THE NORMAL DISPLAY.
tip
Using the Weather Band Station
USING THE WEATHER BAND STATION
1. FOR WEATHER STATIONS, CLICK THE WEAIHER BAND/AM/FM (13) TO “WB”.
2. TUNE FOR THE WEATHER STATIONS BY THE TUNING (14).
tip
Using the Clock
USING THE CLOCK
1. NORMALLY THE LCD CLOCK DISPLAY (6) SHOWS THE HOURS AND TIlE MINIJTES.
2. BY PRESSING SET (9) ONCE THE MONTH AND DATE WILL APPEAR.
3. BY PRESSING SET (9) TWICE THE DISPLAY SHOWS THE SECONDS.
4. TO RETURN TO THE NORMAL DISPLAY PRESS SET (9) ONCE.
tip
Lantern Operation
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
tip
Radio Operation
RADIO OPERATION
1. TURN THE VOLUME ON / OFF (15) CLOCKWISE TO TURN ON THE RADIO.
2. SELECT THE AM OR FM BAND BY THE WEATHER BAND/AM/FM SELECTOR (13).
3. TUNE THE STATIONS BY THE TUNING (14).
4. ADJUST THE VOLUME BY THE VOLUME ON/OFF (15).
tip
Battery Installation
BATTERY INSTALLATION
FOR CLOCK
OPEN THE BATTERY COMPARTMENT DOOR. DRIVE THE SCREW
OUT AND INSERT 1 NEW UM4 1.5V BATTERY INTO THE
COMPARTMENT FOLLOWING THE POLARITIES AS INDICATED.
DRIVE BACK THE SCREW TO LOCK THE BATTERY
COMPARTMENT.
FOR RADIO:
INSERT 4 NEW “SIZE D” 1.5V BATTERIES (FOR RADIO) FOLLOWING THE POLARITIES AS INDICATED.
tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
tip
Cover Page and Contact Information
Jeep Model: JXLWBC
JEEP AM/FM WeatherbandFlashlight Lantern with additional “in package” Flashlight
Customer Assistance Phone Number: 800-354-8785
Power Brands LLC
80A East Jefryn Blvd
Deer Park, NY 11729
Product Made in China
This device complies with Part 18 of the FCC Rules.
This Product may cause interference to radio equipment and should not be installed near maritime safety
communications equipment or other critical navigation or communication equipment operating between 0.45-30 MHz. Variations of this language are permitted provided all the points of the statement are addressed and may be presented in any legible font or ext style.
Modifications not authorized by the manufacturer may void users authority to operate the device
tip
Parts Callout
INSTRUCTION MANUAL PARTS LOCATOR
1. ANTENNA
2. BATTERY COMPARTMENT
3. CARRYING HANDLE
4. COMPASS
5. SPEAKER
6. LCD CLOCK DISPLAY
7. BACK LIGHT (CLOCK)
8. MODE
9. SET
10. FLASHLIGHT
11. LANTERN / FLASHLIGHT / OFF
12. BLINKER I SIREN / OFF
13. WEATHER BAND/AM/FM SELECTOR
14. TUNING
15. VOLUME ON/OFF
16. LANTERN
Manual for Jeep KNG36-JXLWBC AM/FM Weatherband Flashlight Lantern
I just posted a copy of the manual in pdf format on this web site however I have no idea how you would access it.
2/27/2009 3:31:55 PM • Jeep... • Answered on Feb 27, 2009
0answers
Jeep KNG36-JXLWBC AM/FM/Weather Radio Logo
Popular Tags
12 questions posted
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
 Mikey
Mikey
Stan Ford
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jeep Audio Players & Recorders
Most Popular Question
manual jeep kng36 jxlwbc am fm
  • Audio Players & Recorders
