20 Most Recent KLH DAV-502 DVD Player Questions & Answers
Who make's klh 1220 dvd players
It might be this one: https://www.klhaudio.com/ Some extra info here as well: https://en.wikipedia.org/wiki/KLH_(company)
1/21/2019 9:01:51 PM • KLH Televison &... • Answered on Jan 21, 2019
0answers
What size is the fuse to the power cord
Hi, you must check the user guide to find fuse rating or check the blowed fuse for current rating, for a DVD/Bluray player it could be about 2A /120V AC..
7/8/2015 4:25:25 PM • KLH Televison &... • Answered on Jul 08, 2015
MODEL # KF-3228 does not want to turn on tried remote no luck
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
3/15/2015 5:52:58 PM • KLH Televison &... • Answered on Mar 15, 2015
How to change the tv to air from cable without the remote
You should have its remote control to select the inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Type in the brand name of your device in the search box, and press "Enter". Universal remote controls are available at most of the electronic spare part selling shops.
8/3/2014 5:44:50 AM • KLH Televison &... • Answered on Aug 03, 2014
Att uverse hook up hd tv
I do not own a blue ray player but my son has a PS3. The thick cable is most likely HDMI and it should work without the red/white sound cable...try unplugging them so the auto detect feature if available and activated is not trying to compete by finding 2 sources. If that works great! If not, you can get a yellow RCA for the video and just use those as a source - again, don't use the HDMI cable and try it. If you don't have a yellow RCA, I've used another red or white for video testing to see if I can get a video feed. Most newer red/white cable will pass a video signal just fine and are only color coded for ease of hookup.
3/6/2014 2:21:43 PM • KLH Televison &... • Answered on Mar 06, 2014
Tried 0214 code for Dish Network remote. didn't
Hi there! My name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to assist you today and provide you with information that may be helpful to you. Where you trying to address the remote to the TV or a different device? With the *desired equipment* on, press and hold the *desired mode* mode button (about six seconds) on the top of the remote until all mode buttons light up, then release. Press 0-TV/1-VCR/DVD/2-Other, then press STAR Press the Up arrow button once per second while pointing the remote at the *equipment*. If the code for it comes up, the equipment power off. When it does, press the POUND button. If the code entered is valid for the remote, the mode light will flash three times. To verify the code works try several different functions for that equipment.If you have additional questions visit http://www.mydish.com/support/program-to-tv-scan-non-basic?WT.svl=leftnav or contact me directly at: [email protected] Media RepresentativeDISH L.L.C
10/10/2013 8:37:32 PM • KLH Televison &... • Answered on Oct 10, 2013
My KLH DVD-8350 won't go off standy. What do I do?
Standby means just that---all these and TV sets have a standby power supply that runs 7/24 when unit is plugged in---if a voltage is wrong or missing it will not allow or be able to come full on..
11/1/2012 12:19:01 AM • KLH Televison &... • Answered on Nov 01, 2012
0answers
0answers
Need to set channels no remote
can you get in the menu screen with the built in buttons on the TV? if yes then go to menu, go to tuner, select antena or cable, and scan.
6/16/2009 7:18:54 PM • KLH Televison &... • Answered on Jun 16, 2009
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered 55 minutes ago
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered 2 hours ago
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered 6 hours ago
Sorry, but we do not supply parts. This is a website for advice on repairing items. You could try contacting the store you bought it from or contacting iheater directly.
4/19/2024 3:12:50 PM • Televison &... • Answered 6 hours ago
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered 3 days ago
2answers
Changhong tv
Refer its user manual for details.
4/16/2024 3:46:48 PM • Televison &... • Answered 3 days ago
Televison & Video Logo
Popular Tags
0 questions posted
Popular Products
Top KLH Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • KLH Televison & Video
Most Popular Question
klh tv amp t uverse remote control see
  • Televison & Video
