20 Most Recent
Pioneer Dolby Digital 5.1, Pro Logic II and DTS Surround Home Theater System, HTP-2700 System Questions & Answers
No playback with surround system
need heaps more info ill go through my check list when i go out to sort these problems out. this may sound stupid but is it on, is it on mute , is the volume turned down , was it working then stopped, are the audio cables in properly either hdmi or optical try pulling them out and putting them back it sometimes they look like they are in but have slipped out just enough to not work. are the audio cables in the right input, have you got it on the right setting on the amp as in dts not anologue. what have you got plugged in thats not working check all cables even try new ones as i have pulled cables out of the packet brand new and they have been faulty. hope one of these helps if not post more info and ill try to sort it on here :) when you say playback is that audio or video or both??
Install Pioneer surround sound
easy look at the back and treat the holes like a tap water comes out the tap into the drain treat the drain like your amp so what I'm saying connect you tv etc to the inputs of the amp and most people don't need to worry about the out puts on the amp and from the tv or dvd player you need to connect the cable from the out put to the input on the amp :)
I had a picture until my child hit something on
The reset procedure will be in the owner's manual. If you no longer have the manual, look to the Pioneer website. They will have it if it's not too old. Should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through my website. Thank you.
How do i do the digital change over on a dolby
Does your TV have a digital tuner? If so, just do a channel scan and if it detects any channels, they will be stored. You may need to get an antenna depending on how far you are away from the transmission towers.
How to reset a pioneer vsx 456 receiver
To reset your Pioneer VSX-456 receiver, you can try the following steps:
Turn off the receiver.
Press and hold the "Enter" button and the "On/Standby" button simultaneously until "Reset" and "No" appears on your display.
Use the "Preset" arrow buttons to make the display say "Reset" and "Yes" .
Press the "Enter" button on the front panel to confirm .
If this does not work, you can also try unplugging all external devices before beginning the system reset. Switch the receiver into standby mode by holding down "Band" and then pressing and holding the "Standby/On" button for about two seconds. When you see "Reset?" on the display, press the "Preset" arrow buttons to make it say "Yes." Finally, press the "Enter" button on the front panel to confirm .
Pioneer receiver sx218 push power on clicks but nothing in front or any other sounds any ideas
If your Pioneer SX-218 receiver is not producing any sound or showing any indication of power, despite hearing a clicking sound when you push the power button, there could be a few potential causes for the issue:
- Power Supply: Verify that the receiver is properly connected to a working power outlet and that the power cable is securely plugged in. Check for any loose connections or damaged power cords. Try plugging the receiver into a different power outlet to eliminate the possibility of a faulty outlet causing the issue.
- Protection Mode: Some receivers have built-in protection mechanisms that activate in case of a fault or short circuit. This can cause the receiver to shut down and not produce any sound. Check for any obvious issues, such as loose speaker wires or a shorted speaker. Disconnect all speakers and peripherals from the receiver, then power it on to see if it starts up. If it does, gradually reconnect the speakers and peripherals one by one to identify any potential issues.
- Speaker Impedance: Ensure that the speakers connected to the receiver have the correct impedance rating compatible with the receiver's specifications. Using speakers with impedance levels outside the recommended range can cause the receiver to go into protection mode or produce no sound.
- Reset the Receiver: Perform a factory reset on the receiver to eliminate any settings-related issues. Refer to the user manual or the manufacturer's website for instructions on how to reset your specific model. Keep in mind that a factory reset will erase any custom settings and configurations, so you may need to set up the receiver again afterward.
- Internal Component Fault: If none of the above steps resolve the issue, it's possible that there may be an internal component failure in the receiver. In such cases, it is recommended to contact Pioneer customer support or consult a qualified technician for further diagnosis and repair.
Remember to consult the user manual for your Pioneer SX-218 receiver for specific troubleshooting steps and instructions tailored to your model. If you are unsure or uncomfortable performing any troubleshooting steps, it's best to seek professional assistance to avoid causing further damage to the receiver.
