20 Most Recent
Pioneer AVIC-X1R CD Player Questions & Answers
Hi, I have a pair
hello,the cd player that does not read cd's properly,it's simply because of a weak or bad laser lens,so all you need to do is to get a new laser lens and replace it with the faulty one and you will have your cd working as normal.
the one that will not turn on properly,
this is simply because the power I.C is weak or bad,so it has to be replaced so as for you to have it power on properly...
wish you good luck,
take care.
Hi, my oil light on
the oil light can be 4 typs of fluid.. The Transmission, engine, brake and power steering fluid,, Check them all...
If they are all fine then chances are the oil level sensor is bad and needs changing..
Avic x1r screen fault
Check
flexi cable to the screen[issue with the AVIC-X1 range and pioneer service centres have been replacing them free of charge if the head unit's under 4 years old].OR it might be with monitor PCB to get fixed.OR give a Call to 020 8845 1525(Go this Link).
OR For Service manual Link(Payment required).
Hope this Helped you..Thanks for Contact FixYa..
I have a pioneer avicx1r and when i try to eject a
The problem is the disc. It is most likely warped. I had the same issue and I actually removed the unit from the dash still connected, tapped the top and pushed the eject button and out came the disc. I played a little longer and reinserted the disc and it showed the error again, tapped it and ejected it then tried another disc and no problem at all. I tried several and they all worked and every so often tried the original one and it showed error each time. It seems as though the fact it was warped it was catching the unit or a sensor was seeing it as a problem and not allowing it to eject. Hope this helps
X1r fault
Call 1-800-pioneer and ask for technical support.They are good!
solutiondoct
New Fascia?!
1-800-pioneer.Give out your model to the tech.,and he will tell you the part that you need.
Tuesday-Thursday between 7-8am would be the best time to call!
solutiondoct
Avic X1R Radio Only
ribbon gone, common problem cost £120 to fix (don't know why cos ribbon only cost £35), just got mine fixed
