20 Most Recent Radio Shack 4-in-1 Kameleon Touch-Screen Universal Remote Questions & Answers
If you have done a code search method, and it too doesn't help you, the remote control you have had no setup codes to synchronise with. Give it up, and buy an new one, which has setup codes for your device.
Radio Shack... | Answered on May 10, 2012
Here is the manual. It helped with all devices but my magnavox cd. The codes in the book did not work, nor did the search method. The tv and the vcr search worked. Good Luck, Dan
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502144_PM_EN.pdf
Radio Shack... | Answered on Sep 15, 2008
Hello, you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Radio Shack... | Answered on Dec 21, 2007
If you have the model number of the Radio Shack universal remote, that would help tremendously. There are several that were made.
If it's the model 15-302, here are the codes to try. They may or may not work on other models.
Philips 010,018,020,026,038,043,044,070,101,106, 134,139,150,151,205,210,217,218,257,267,285,290,302,303,314,325,382,396,400, 419,444,445
Radio Shack... | Answered on Mar 11, 2019
This remote control have no set-up codes to Vizio. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Radio Shack... | Answered on Nov 29, 2018
You can find the manual for the Radio Shack 4-in-1 Remote 15-2142 at ManualsLib and some other sites. A direct link to the PDF of the manual is here: http://www.rockabilly.net/files/manuals/15-2142.pdf . The ManualsLib version of the manual: https://www.manualslib.com/manual/635735/Radio-Shack-4-In-1-Remote-Control.html . The only code listed for a Magnasonic VCR is 0593. No Magnasonic DVD players are listed. If your Magnasonic DVD/VCR was built more than 6 months before the remote was programmed, then the remote has the best chance of having the correct code. The copyright date for the manual appears to be 1999.
I hope this helps. You may want to try searching through all of the codes. Many electronics manufacturers use a common supplier for the IR sensor chip and encoding.
Radio Shack... | Answered on Sep 28, 2018
Codes would be for what .you are trying to connect to, not the remote itself
Radio Shack... | Answered on Jun 07, 2018
Check for fuses first, Some fuses are soldered to the board and not easily identified unless you read the printing on the board. Over volting can cause filter caps to open as well as the power transformer winding's. Some transformers have fuses buried inside, Test the windings with an ohm meter. No reading would indicate an open internal fuse. Doing surgery on that type of transformer can restore it by taking the fuse out and joining the wires.
Radio Shack... | Answered on Mar 31, 2018
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Radio Shack... | Answered on Dec 31, 2017
Televison & Video Logo
14 questions posted
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Joe Negus
Joe Negus
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Radio Shack Televison & Video
Most Popular Question
kameleon remote control 15 2136
  • Televison & Video
