20 Most Recent
Amana NAV2335A Top Load Washer Questions & Answers
I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
How to replace drive belt
Nothing could be simpler. No tools needed. Tip the washer on it's back and ease the belt back on there.
Before you mount another belt on there you need to check the pump for stiffness. On these washers the pump sometimes locks up and burns a belt up. If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
What size is an Amana
I had the very same question, so I can buy a replacement that is just as big. Not finding the answer online, but only your question, I measured mine and calculated the volume at about 2.5 cubic feet. I am surprised it seems so small, because it is labeled as an extra large capacity. Of course, it is now about 15 years old, so maybe the new ones are mega washers or something. I wonder if I will get that much time out of a new one.
Wont spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Iget alot of lint in my laundry cant find lint
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it (or if the vent itself has finger holes or something that you can grab and pull or slide it open).
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it (or if the vent itself has finger holes or something that you can grab and pull or slide it open). All dryers have a lint trap (building codes probably even require it).
