20 Most Recent
SanDisk 16Gb USB Flash Drive Questions & Answers
My pen drive not formating
Hi,Is your pen drive detecting while connecting to system then use the below process
To format a USB stick to FAT with Windows, follow these instructions: Open the Control Panel, Select Administrative Tools, then go to Computer Management, Select Disk Management, Right click on the drive letter corresponding to the USB drive and select Format, If the key has a capacity of more than 2 GB, choose FAT32. Confirm with OK. To format a USB flash drive to NTFS, follow these steps: Put the key into the USB port and wait for it to be recognized as a mass medium. Go to Start/My Computer. The USB key is visible in Devices with Removable Storage. Right click on the key, then go to Properties/Hardware. Double click on the USB drive icon. Go to the Policies tab and select Optimise for performance. Click on OK. Go back to My Computer. Right click on the USB drive and then choose Format. Choosing NTFS has become possible, in addition to FAT option.
Hey, was wondering how could I be able to use my OTG SanDisk duel 16Gb 3.0 USB drive on my Cellphone.... Mobicel V4
To use your SanDisk Dual USB Drive (OTG) on your Mobicel V4 smartphone, follow these steps:
1. Make sure your Mobicel V4 supports USB On-The-Go (OTG) functionality. Not all devices have this feature, so it's essential to verify its compatibility beforehand.
2. Connect the SanDisk Dual USB Drive to your Mobicel V4 using the micro-USB or USB Type-C connector (whichever is compatible with your phone's port).
3. Your Mobicel V4 should recognize the USB drive automatically and prompt you with a notification or a file manager app may open automatically. If nothing happens, proceed to the next step.
4. Go to the Google Play Store on your Mobicel V4 and search for a file manager app that supports OTG functionality. Some popular options include ES File Explorer, Solid Explorer, or Total Commander. Install the file manager app of your choice.
5. Launch the file manager app and navigate to the "Storage" or "External Devices" section. You should see the SanDisk Dual USB Drive listed there.
6. Tap on the USB drive's icon to access the files stored on it. From here, you can copy, paste, or manage files just like you would with any other file manager.
7. When you're finished using the USB drive, make sure to safely eject it from your Mobicel V4. This can typically be done through the file manager app or by going to the system settings and selecting the USB device to eject.
It's important to note that the specific steps may vary slightly depending on the file manager app and the Android version running on your Mobicel V4. However, these general instructions should help you connect and access files on your SanDisk Dual USB Drive using your smartphone's OTG functionality.
5/24/2023 6:09:26 AM •
SanDisk...
Answered
on May 24, 2023
How can i unwriteprotect my 16gb sandisk flashdisk
Open up a command prompt as administrator
Type diskpart and press Enter
Type list disk, and you'll get a listing of all drives on your machine.
Type select disk # to select a disk. You can use the Size column to identify which one it is.
Type attributes disk clear readonly - change your USB's properties so that it is no longer read-only.
5/31/2018 7:15:13 AM •
SanDisk...
Answered
on May 31, 2018
My sandisk pen drive is write protected
Remove write protection from Sandisk pen drive with write protection removal software. Double-click on the WriteProtect value in the right-hand pane of Regedit.exe. Change the Value data from 1 to 0 and click OK to save the change. Close Regedit and restart your computer.
5/24/2018 9:28:11 AM •
SanDisk...
Answered
on May 24, 2018
