20 Most Recent Asko T781 Electric Dryer Questions & Answers
2answers
Asko T781 Electric Dryer Doesn't Turn On
Have you reset the cut out on the back? its a little black button that you push in until it clicks. If it does not click, then it probably wasnt the problem. The next most likely cause is a melted fuse holder inside the box on the rear where the power cord goes in. There is a bypass kit available to repair this problem from ASKO, as the fuses are not needed. If you are able to do some simple wiring, you can do this. Otherwise find an AUTHORIZED asko servicer and they will know what I'm talking about. Good luck!
4/19/2014 11:10:38 PM • Asko T781... • Answered on Apr 19, 2014
3answers
I have an ASKO T781 Dryer that suddenly will not
I just had this same problem, The fuses were not attached to anything. I stumbled upon a black button, that looks sort of like a gromet. Push that, it's a reset button. If it clicks, there you go. It could mean something else is wrong, but that should be a starting place.
4/19/2014 11:02:41 PM • Asko T781... • Answered on Apr 19, 2014
0answers
Clunking noise
Be the first to answer 4/16/2014 3:14:30 AM • Asko T781... • Posted on Apr 16, 2014Be the first to answer
How to remove the front cover of the dryer asko T781
Service Manual Dryers EN Asko 700 Series pdf Google Drive ASKO TRAINING MANUAL PDF If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1/30/2014 6:06:52 PM • Asko T781... • Answered on Jan 30, 2014
The display doesn't work
Asko are not very common in many areas and so not many people can mentally remember what this model looks like. However, if the display doesn't not work: Try unplugging it for five minutes or just removing the power for that time. See if it resets.Not sure what 'does not work' means...no light, no response to touch..respond but does not start..???Give more info if you seriously nee people who are not at the machine to help you.
10/17/2013 5:20:27 AM • Asko T781... • Answered on Oct 17, 2013
0answers
Dryer shuts down
Be the first to answer 9/23/2013 5:01:10 AM • Asko T781... • Posted on Sep 23, 2013Be the first to answer
manual
T781 Electric Dryer Manual
Asko DryersUploaded on Aug 26, 2013
3answers
Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
9/21/2011 6:26:14 AM • Asko T781... • Answered on Sep 21, 2011
My dryer is starting to sound noisy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
7/4/2011 8:04:56 PM • Asko T781... • Answered on Jul 04, 2011
Asko 7005 dryer, start capcitor is cracked and has
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
6/19/2011 9:16:59 PM • Asko T781... • Answered on Jun 19, 2011
Asko 7005 Dryer, would not stay running unless
Definitely replace the capacitor. You can test the heat element with an ohm meter. If you have continuity, it is normally good.
6/17/2011 6:27:12 PM • Asko T781... • Answered on Jun 17, 2011
Disconnected wiring harness from timer,and
Hello & Welcome to FixYa
You can check its repair manual here for the wiring diagram and installation instructions. Please get back to me if you have any other questions.
Kevin
6/15/2011 3:55:18 PM • Asko T781... • Answered on Jun 15, 2011
Where can I find a: explosion diagram for ASKO
Hi.
Here the full service manual:Click here to start download..
Here an alternative link: Asko Condenser Dryer Service Manual.
Regards.
Ginko.
I
1/3/2011 1:50:03 PM • Asko T781... • Answered on Jan 03, 2011
2answers
My Asko T781 Dryer keeps
Check the exhaust vents for any obstruction of lint inside of it. Lint holds moister & the moister sensor will shut down the dryer
8/11/2010 11:51:46 PM • Asko T781... • Answered on Aug 11, 2010
2answers
My dryer is making an increasingly noisy rolling
sounds like your drum guides or felt thats wore
out or something stuck inside there rubbing
7/28/2009 2:27:34 PM • Asko T781... • Answered on Jul 28, 2009
Asko T780 Dryer Vibrating/Grinding noise
Sounds like a bad roller. You'll have to remove the drum to get at them. Even a free one may make noise at speed. Use high temp grease. Also check roundness. And don't forget the belt tensioner roller, just don't get any grease where the belt touches.
4/23/2009 4:59:31 AM • Asko T781... • Answered on Apr 23, 2009
Asko T781 dryer trips on over temperature
The problem is probably that it is much lint in the fan, and/or in the back of the drum, so the air is unable to cirkulate fast enough. OR it can be that you are overfilling it with laundry.
4/1/2009 7:31:14 PM • Asko T781... • Answered on Apr 01, 2009
Disabled neighbor was given an
most likely if the dryer does everything except heat up the heating element is bad if you take it apart it will be directly behind the holes inside the dryer
1/15/2009 2:59:18 AM • Asko T781... • Answered on Jan 15, 2009
Asko T781 Electric Dryer Logo
31 questions posted
Top Asko Dryers Experts
Mat Kramer
Mat Kramer
Level 1 Expert
Paul Carew
MattS1978
Level 1 Expert
Are you an Asko Dryer Expert? Answer questions, earn points and help others
View Most Popular
Asko Dryers
  • Asko Dryers
Most Popular Question
find explosion diagram asko
  • Dryers
