20 Most Recent Maytag 22.1 cu. ft. Bottom Freezer Refrigerator w / Factory Installed Ice Maker Questions & Answers
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Maytag 22.1 cu.... | Answered on Sep 19, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Maytag 22.1 cu.... | Answered on May 20, 2011
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Maytag 22.1 cu.... | Answered on Apr 09, 2010
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Maytag 22.1 cu.... | Answered on Feb 11, 2009
Try to verify the freezer selector, maybe it malfunctioning, else maybe it need a general cleaning on its parts. For most accurate troubleshooting you may call on the nearest repairman.
melnavz
Maytag 22.1 cu.... | Answered on Feb 10, 2009
Is fan running in frzr? IF not, then it is bad and needs replacing. Common issue.
Maytag 22.1 cu.... | Answered on Nov 28, 2008
Unplug the ref for a couple of hours ( let the compressor cool off) plug it back in. If it still clicks, replace the relay, if the compressor still won't start then the compressor is bad. Last rights at this point would be appropriate.
Maytag 22.1 cu.... | Answered on Nov 27, 2008
Defrost circuit problem, the snow means that your freezer coil is not being automatically defrosted. This could be a problem with the defrost heaters or defrost timer. Also in the newer models a module
controls this operation. Call for service. Removing ice or snow from the back wall is not the solution. The coil behind the back wall is also frozen and no air is circulating.
Maytag 22.1 cu.... | Answered on Oct 19, 2008
what make and model is it....
Maytag 22.1 cu.... | Answered on Feb 15, 2008
Slide the frig out, (Unplug Frig. first) remove the cover so you can see the condenser, beside the condenser there is a switch that has to be carefully removed w/(fasteners) Take to your nearest appliance store, last time I did this it was like $52.00. Carefully plug-in, take not were the wiring goes usually they only fit just one way. reassemble cover, plug-in you should hear it kick on, good luck.
Maytag... | Answered on Oct 01, 2019
If you go to https://www.filtersfast.com/Maytag-Refrigerator-Water-Filters-cat.asp
It will show you styles of Maytag Refrigerators. If you click on the one that matches your style, it will show you possible areas the filter is located. You can then look in those areas. Once you locate it, then you can then identify your filter part # and replace if needed. You can also go to Maytags website and look up your model and find the manual. The manual will likely tell you where the filter is and what the part number is.
Maytag... | Answered on Sep 17, 2019
Is icemaker switched on. Usually located near icemaker/ Or maybe faulty switch
PLEASE CHECK THE CONNECTION CAREFULLY AND THEREAFTER IF NOT WORK THEN CONTACT TO WELL MACHANIC.
Maytag... | Answered on Sep 15, 2019
There may be a drip tray under the fridge, it needs to be checked and position properly
Maytag... | Answered on Aug 22, 2019
Sometimes the new board will be in defrost mode when you install it, leave it powered up for 30 minutes to see if it begins cooling... Maytag Refrigerator Control Board W10890094
Also be sure the code is entered properly, these will do NOTHING without the right code.
Maytag... | Answered on Aug 07, 2019
Maytag 22.1 cu. ft. Bottom Freezer Refrigerator w / Factory Installed Ice Maker Logo
22 questions posted
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
fan running but
  • Refrigerators
