20 Most Recent
Konica Minolta Bizhub Pro C500 Questions & Answers
SC 33-02 error code
Sir/Mam,
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!! Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub pro c500 error sc32-07
Printer control board (PRCB)
Paper exit fan /1 (M61)
Paper exit fan /2 (M62)
Paper exit fan /3 (M63)
Note:
• Since the old type is not
installed with the M61, M62
and M63, be sure to check
to see if the 25 DIPSW is set
as shown below:
Old type: DIPSW 21-0-0
have a tech check this problem Btw, I’m available to help over the phone in case u need at
Scanner settings Bizhub Pro C500
The communication can only be complete when the IP Address is fully established. This is in the manual and information on doing a set up is detailed by Minolta. Only you or a technical person with privileges who you invite into your computer can resolve that issue.
