20 Most Recent
Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher Questions & Answers
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Dishwasher will not start
push and hold that button in for 3 - 5 seconds i believe the control was locked. let me know if you need further assistance or if this solves the problem
There are cut wires and no cord for the second
There should be a small junction box under the dishwasher behind the front toe panel. There should be three wires:
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
You can purchase a three conductor power cord from any hardware store. A 3-prong power tool power cord works the best, as they have a durable outer sheathing and have good current handling properties.
Simply match the corresponding colors (black to black, white to white) and ground the green wire to the chassis. There should be a ground lug somewhere to connect it to.
Use wire lugs when splicing wires together and use the wire strain relief (if equipped) on the junction box. The strain relief is located at the point where the wire enters the junction box and keeps the wires from inadvertently being pulled.
If you have any questions, please post back and let me know. I hope this helps you.
All buttons are basically dead.
Hi
If you believe that the door switch-latch assembly is fine, and
then check the thermal fuse located on the control board, if that is bad the
unit won't work. Hope this helps...please post back for further assistance.
Daniel
Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Dishes are not getting clean at all, also have
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info. You will love the results!
Hi Expert, I have Maytag MDB5600AWS dishwasher.
i have seen alot of these that get a stripped out wash impelle. they have a new seal kit and impellerfor these and it seems to be pretty common.
the kit has the install tools and instructions to do it properly.
take the pump apart from the top and see if the impellers look worn or stripped out.
