20 Most Recent
Fanimation Pedestal in White with Standard 3 Speed Remote Control Questions & Answers
It does not work !
Check the power cord and switch if the unit is completely dead. If there is a humming noise, check the bearings in the motor and gearbox (gearboxes are generally found only in oscillating fans).
Faqe7077kw0 dryer beeps 3 times won't start replaced the door switch same problem. Hold in the select button and press start and it will run until I let up on the select button
- Check the Power Supply:
- Ensure that your dryer is receiving proper power. Use a multimeter to test the wall plug. You should have two poles giving 110-120 volts each and a ground. If only one side is hot and the other is not, you could have issues.
- Common Causes for Dryer Not Starting:
- Let's explore some common reasons why your dryer might not start:
- Thermal Fuse: The thermal fuse is a safety device that protects the dryer from overheating. If it's blown, the dryer won't start. Test it for continuity using a multimeter Check your exhaust vent for restrictions..
- Start Switch: If the dryer hums but doesn't start, the start switch might be faulty. Test it for continuity with a multimeter.
- Door Switch: The door switch activates when the dryer door is closed. Listen for a "click" when you start the dryer. If you don't hear it, test the door switch for continuity.
- Door Switch Solution:
- If the door switch isn't "clicking," it might be the culprit. Try this:
- Push the length of the switch from side to side (without removing it) to see if it clicks.
- If it clicks, it's likely not defective.
- Reassemble the dryer to see if it works.
Remember to
safely disconnect the power before attempting any repairs. If these steps don't resolve the issue, consider seeking professional assistance or further diagnostics
3/13/2024 3:16:44 AM •
Dryers
Answered
on Mar 13, 2024
