20 Most Recent Maytag Neptune MDG6700A Gas Dryer Questions & Answers
3answers
Have a Maytag MDG6700AWW gas
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a MDG6700AWW Maytag gas dryer. I'm not sure if you know this but this particular Maytag is built by Samsung.
If this is a symptom where the ignitor does glow and ignite the burner the first time but not the second ignition, I would be looking at the burner coils.
This is similar to what you'll be looking for...
Once you've gain access to the coils you'll need to remove the wire harness and check the continuity.
Here's the tricky part though...many times they will ohm out ok when cool (not operating) yet as soon as there is current passing through the coil for a period of time it "opens". The wire inside the coils is so fine that often it only takes a small current to "open" the circuit...thus not igniting the 2nd, 3rd time and so on.
Most times it will only be one coil that fails but it is good practice to replace them both, many places used to sell them in a kit so double check with your supplier. I've attached a link here, though it may be different than your model the principles to changing the coils are the same.
As far as what part you may need and how to get it. There are a couple of places I prefer, on-line at "searspartsdirect.com" or "repairclinic.com".
Kit contains both the two wire and three wire solenoids. One solenoid is the primary and one is the safety. Both have to operate for the gas valve to open. Usually, one of them burns out as I said but you should always replace them as a set, thus it is usually sold this way.
**unplug the appliance and turn off the gas supply before attempting any service...safety first**
The common coils (this included your Maytag built by Samsung) is part number 35001190 at "repairclinic" as this link should provide you.
Let me know how you make out or if you require further assistance and I'll do whatever I can. Good luck.
Regards,
Macmarkus :)
1/11/2018 12:19:32 AM • Maytag Neptune... • Answered on Jan 11, 2018
Why wont my Maytag Neptune gas dryer stay hot when I'm drying my cloths?
If you are sure that it is a gas powered dryer, the problem could be thermostat, flame sensor etc.
10/5/2015 8:36:48 PM • Maytag Neptune... • Answered on Oct 05, 2015
Dryer will heat at start, then stops heating for the remainder of cycle ?
heating element may need to be replace check element
9/22/2015 3:01:42 PM • Maytag Neptune... • Answered on Sep 22, 2015
E5 code no top on the E
The code is T5 and that is the thermistor Check for: - Clogged lint screen. - Restricted vent system. - Check Thermistor resistance. Thermistor resistance 10K ohms at 25 C 77 F (2P-Blue & Red wire) - Check for diagnostic code 1 Use tech sheet in machine to enter diagnostics mode
8/28/2014 11:48:29 PM • Maytag Neptune... • Answered on Aug 28, 2014
Error codes 3 and 10
need to test with multimeter, door code error could be a faulty door switch which would hinder machine from operating. I suggest checking the glo bar and ceramic igniter for the going off problem, in electric dryers maybe in gas as well bad motor windings can cause it to go off and on?
8/18/2014 5:29:49 PM • Maytag Neptune... • Answered on Aug 18, 2014
Why is my dryer not drying?
could be a bad venting situation? lots of lint? kinked or clogged vent lines? or might want to have ur heating element checked with a multimeter most appliance parts stores will do it for free, ( if they have the impression u will be buying one from them) also have ur cycling thermostat checked and the hi-lo thermostat just to be on safe side
8/16/2014 3:45:10 PM • Maytag Neptune... • Answered on Aug 16, 2014
How to remove front of mdg6700aww
Remove the top then you can get to the screws on the console it has screws on top and tabs on the bottom then you will see the screws along the top of the front panel it is slotted at the bottom always unplug before working on electrical appliances
6/29/2014 8:21:40 PM • Maytag Neptune... • Answered on Jun 29, 2014
How to remove front
The first step is to take out the screws that hold on the door. Now look across and you will see two more screws holding on plastic clips. Those are there so the door can be mounted left or right . The door will come off with a little up and down motion. Now grab the metal frame on both sides ( where the door was mounted) and it will snap off. The rest you should be able to figure out. Hope this helps. Wayne.
6/29/2014 1:41:34 PM • Maytag Neptune... • Answered on Jun 29, 2014
0answers
Mdg6700aww
Be the first to answer 1/26/2014 3:32:31 AM • Maytag Neptune... • Posted on Jan 26, 2014Be the first to answer
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
5/21/2013 8:51:28 AM • Maytag Neptune... • Answered on May 21, 2013
Maytag mdg6700aww dryer clicks to
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
8/15/2011 3:19:06 AM • Maytag Neptune... • Answered on Aug 15, 2011
Why will my dryer not turn on. Had been working
Please check the electrical outlet in and around the area in which your appliance is plugged into. Even thou the breaker, fuze, and cable are fine, you will have to PUSH IN the cut off TRIP button located on the AC plug in panel. There are several located throughout most kitchen/appliance areas that will cut off all electricity to a specific set of plugs. If you still need help, please return.
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
PROVIDING FEEDBACK WILL ALLOW US TO CONTINUE SUPPORTING YOU IN EXPERT SOLUTIONS Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
1/11/2011 4:37:20 PM • Maytag Neptune... • Answered on Jan 11, 2011
Problem with the Maytag Neptune
Hello & Welcome to FixYa
When the dryer heats for few minutes and then it won't work it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this part for continuity before replacing. Please get back to me if you have any other questions.
Kevin
12/2/2010 10:57:41 PM • Maytag Neptune... • Answered on Dec 02, 2010
Flam goes out after a few seconds
Did you ever figure out the problem? I am having the exact same issue - please share your solution! Thanks!!
11/16/2010 6:40:07 AM • Maytag Neptune... • Answered on Nov 16, 2010
Maytag Neptune MDG6700A Gas Dryer Logo
Popular Tags
23 questions posted
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
problem maytag neptune
  • Dryers
