20 Most Recent
Shure 55SH Series II Professional Microphone Questions & Answers
Level sound low
Make certain to use a mic preamp that has at least 60 dB of gain.
Shure 55 sh dead?
You are best to send the mic to Shure for repairs. They can certainly get it working for you. www.shure.com/service
Hi. I've connected my Shure
Most likely the 1/8" jack's input is LINE level. The microphone works at a higher IMPEDANCE and will have to be boosted to line level in order to have a matching impedance to the input on your netbook. You can use a mixer, a DI box, or microphone pre-amp to match the LINE level of your 1/8" jack. That will give you more control over level with less noise.
I need a wiring diagram/schematic
There is a wiring diagram on page 10 of the User Guide.
http://www.shure.com/americas/products/microphones/classic/55SH-Series-II-iconic-unidyne-vocal-microphone
I have a two yr. old 55sh series 2 that just quit
If you do not have experience in repairing these mics, you should probably have a pro audio technician do the work. The problem is an open circuit in microphone's internal wiring; either the mic cartridge is dead, or one or more of the fine wires connecting it to the microphone output connector are disconnected. Sometimes the fault is caused by a bad solder connection, or a faulty switch. As I mentioned, unless you have experience with these items, you can permanently damage a potentially salvageable mic. A goos tech should be able to identify the problem in a few minutes, and if the mic is repairable, it should be a cheap fix. Worst case scenario, a dead cartridge replacement may cost half the price of a new mic. But then, it's essentially a new mic.
SHURE BLX4R BATTERY LIGHT OFF AND WONT SYNC - HELP!
please attempt to factory reset your microphone. Also, some companies only allow certain accessories like a battery to be provided by them or special partner companies. So, please verify with your manufacturer that duracell batteries are allowed to be used within their products.
Thank you.
