20 Most Recent
Avanti (WDE79BSS) Questions & Answers
Avanti water cooler
check the switch at back if it is working, check the motor compresor touch the top of the motor comp, if working, the possible problem is the freon, touch the condenser at the back of the unit if hot the freon is working, if no hot, load a freon, ok
7/24/2019 9:54:52 PM •
Avanti...
Answered
on Jul 24, 2019
There is a full 5
Something is obviously clogged.
Try opening the valves and blast some air through perhaps from a tire compressor.
Of course use common sense and don't apply pressure to jugs, etc.
11/19/2017 8:03:45 PM •
Avanti...
Answered
on Nov 19, 2017
Hi! I purchesed washer mashine Avanti W798SS a few
If it's still under warranty. Go to the store where you bough from
and ask them about. They'll ask an authorize from the factory and the will find some one to fix for you.
Good luck
Mai
5/16/2017 6:03:31 PM •
Avanti...
Answered
on May 16, 2017
Refrigerator get warm for several days then cools down.
The problem with your fridge may be the compressor being out of gas or a faulty thermostat. If it is the
thermostat is it easy to get a new one and fit it?
Well, the thermostat could be tested with a multimeter.
you could get replacement parts at an electrical supply store or an
appliance repair shop.
Thanks for contacting Fixya.
7/16/2010 6:50:43 PM •
Avanti...
Answered
on Jul 16, 2010
Makes ice but will not dump the ice,
Hi,If you have a steady blinking light when you open the door then the sensor is working. In these cases the problem is usually in a bad motor or thermostat in the icemaker.
The solution is to replace these parts, If you need I can give you instructions on how to change these parts.
Thanks and Good luck
6/24/2010 10:39:48 PM •
Avanti...
Answered
on Jun 24, 2010
Avanti wc1500dss wine chiller not getting cold but does the opposite gets hot
https://manualsdump.com/en/manuals/avanti-wc1500dss/66172/12
The above has a troubleshooting matrix.
Power supply: Check if the wine fridge is receiving power from the mains supply. If it's not, there might be a major issue with the mains power or the PSU circuit board in the product that'll likely need replacing if it's faulty.
Condenser fan: The condenser fan is designed to cool the condenser and condenser coil within the Avanti wine cooler. If it doesn't function, the condenser and coil can overheat - causing the internal area of the wine fridge to heat up too. Take a look at the rear of the unit and make sure the condenser fan is spinning freely and not blocked (by dust / dirt) or making excessive noise due debris or a blockage.
Thermostat: If the Avanti wine fridge thermostat is working correctly, it's responsible for making the condenser, evaporator, fan, and compressor work - so it's super important! The thermostat also allows you to control and adjust the temperature of the wine cooler so if the reading on thermostat is inaccurate (or flat out wrong) the wine cooler temperature will likely be inaccurate too.
Why Is My Avanti Wine Fridge Not Cooling (And How To Fix It) - Expert Wine Storage
10/26/2023 12:56:30 PM •
Avanti...
Answered
on Oct 26, 2023
Avanti WCR683DZD-2 LED panel blinks when plugged in. Fan or compressor does not come on. Where should I start to begin trying to repair the unit
If your Avanti WCR683DZD-2 wine cooler's LED panel is blinking when plugged in and neither the fan nor the compressor comes on, there could be a few potential issues. Here are some steps you can take to begin troubleshooting and attempting to repair the unit:
- Check power supply: Ensure that the wine cooler is receiving power by verifying that the outlet is functioning correctly. Try plugging in another device to confirm if the outlet is working properly.
- Inspect the power cord: Examine the power cord for any signs of damage or wear. Make sure it is securely plugged into the wine cooler and the power outlet.
- Check the control board: The blinking LED panel suggests a possible issue with the control board. Inspect the control board for any visible signs of damage, such as burnt components or loose connections. If you are knowledgeable about electronics, you can attempt to repair or replace the control board. Otherwise, it may be best to consult a professional technician or contact Avanti for further assistance.
- Test the temperature control thermostat: The thermostat controls the operation of the fan and compressor. Using a multimeter, you can check the continuity of the thermostat to determine if it is functioning correctly. If it is faulty, it may need to be replaced.
- Examine the compressor: Inspect the compressor for any visible issues, such as loose connections or damaged wires. Ensure that it is receiving power and that the compressor motor is not overheating. If the compressor is not running, it may require professional servicing or replacement.
7/2/2023 2:59:52 PM •
Avanti...
Answered
on Jul 02, 2023
I have an Avanti BCA280 that won't cool.
The most likely reason for commercial coolers and fridges not cooling is a low gas state. Did you get your gauges out and check the high and low side pressures before you started swapping parts out?
3/2/2022 5:18:08 PM •
Avanti...
Answered
on Mar 02, 2022
