20 Most Recent
Avanti Compact Thermoelectric Refrigerator Questions & Answers
Bought a used Avanti refrigerator
fridge settings numbers are the smallest number 1 is the coldest for the fridge
freezers or the opposite so 1 is the warmest
check the freezer door seals
Not getting very cold
thermoelectric needs a good heat dissipation. Give the unit a good ventilation to dissipate the heat, you will cool the unit. The cooler the ambient, the cooler the box. Remember not to reverse the switch, you will get a heated box instead.
The fan makes a lot of noise, is there a way to
The type of refrigerator you have uses a solid-state device which likely uses a Peltier effect element.
This uses electricity to transfer heat and cold on opposite sides of the element, absorbing heat from within and radiating it from the other side being cooled by the fan.
With no moving parts other than the fan, they are very reliable but also very dependent on ridding the element of the absorbed heat which necessitates fairly high air flow to function properly.
If a fan was used that produced less noise, the airflow might be too little to allow the element to cool the interior efficiently.
Unless the fan has a defective bearing, which would reveal itself by a rattling sound, it is probably still working as it should.
My avanti thermoelectric compact refrigerator
The noise if from a sympathetic vibration of the unit which transforms to vibrate any loose joints, parts or fittings.
You will need to listen to the noise, use your hand to hold up the plastics or the joints in the bottom section of the unit or the frame work. It will require a lot of patience to find the source of noise. Pad it up after tapping for loose noise on the rear and insulate the noise heard till you finally get rid of any vibration noise..
Compressor is running, but the box is not cooling.
leave the fridge for some time for the gas in the compressor to settle, after like 30 minutes, you can now power on back.
Is the fan running at the back, if yes, then, you will need to check the thermostat in your fridge to see if it is set to cold. I assume you set the air balance control in the refer. section to a
colder setting and didn't just adjust the freezer section by itself?
Also remember that it takes approx. 24 hours to cycle to a new set temp.
so make adjustment and check a full day later. (use a themometer in
refer. to see temp). If freezer is a proper temp then the unit should
be ok as the freezer cools and then transfers cold air to the refer.
thru ports. Make sure these are not blocked.
See the manual for the settings to cold on the thermostat in the fridge, after the thermostat in the fridge is set to cold, leave it and wait for sometime to see the difference.
Please see the manual to see the appropriate settings and standard for your fridge.
Take care.
Will not keep cooling shuts off
Sounds like a your problem may be in the thermostat. Reason I say that is because when you leave the door open it continues to run and freeze and frost is seen on the freezer walls. I just think maybe the thermostat has become less sensitive to temperature change. To test this unplug the freezer and connect the 2 wires to the temp control together. Then the refrigerator will run continuous until unplugged. Let me know, Sea Breeze
Avanti wc1500dss wine chiller not getting cold but does the opposite gets hot
https://manualsdump.com/en/manuals/avanti-wc1500dss/66172/12
The above has a troubleshooting matrix.
Power supply: Check if the wine fridge is receiving power from the mains supply. If it's not, there might be a major issue with the mains power or the PSU circuit board in the product that'll likely need replacing if it's faulty.
Condenser fan: The condenser fan is designed to cool the condenser and condenser coil within the Avanti wine cooler. If it doesn't function, the condenser and coil can overheat - causing the internal area of the wine fridge to heat up too. Take a look at the rear of the unit and make sure the condenser fan is spinning freely and not blocked (by dust / dirt) or making excessive noise due debris or a blockage.
Thermostat: If the Avanti wine fridge thermostat is working correctly, it's responsible for making the condenser, evaporator, fan, and compressor work - so it's super important! The thermostat also allows you to control and adjust the temperature of the wine cooler so if the reading on thermostat is inaccurate (or flat out wrong) the wine cooler temperature will likely be inaccurate too.
Why Is My Avanti Wine Fridge Not Cooling (And How To Fix It) - Expert Wine Storage
10/26/2023 12:56:30 PM •
Avanti...
Answered
on Oct 26, 2023
Avanti WCR683DZD-2 LED panel blinks when plugged in. Fan or compressor does not come on. Where should I start to begin trying to repair the unit
If your Avanti WCR683DZD-2 wine cooler's LED panel is blinking when plugged in and neither the fan nor the compressor comes on, there could be a few potential issues. Here are some steps you can take to begin troubleshooting and attempting to repair the unit:
- Check power supply: Ensure that the wine cooler is receiving power by verifying that the outlet is functioning correctly. Try plugging in another device to confirm if the outlet is working properly.
- Inspect the power cord: Examine the power cord for any signs of damage or wear. Make sure it is securely plugged into the wine cooler and the power outlet.
- Check the control board: The blinking LED panel suggests a possible issue with the control board. Inspect the control board for any visible signs of damage, such as burnt components or loose connections. If you are knowledgeable about electronics, you can attempt to repair or replace the control board. Otherwise, it may be best to consult a professional technician or contact Avanti for further assistance.
- Test the temperature control thermostat: The thermostat controls the operation of the fan and compressor. Using a multimeter, you can check the continuity of the thermostat to determine if it is functioning correctly. If it is faulty, it may need to be replaced.
- Examine the compressor: Inspect the compressor for any visible issues, such as loose connections or damaged wires. Ensure that it is receiving power and that the compressor motor is not overheating. If the compressor is not running, it may require professional servicing or replacement.
7/2/2023 2:59:52 PM •
Avanti...
Answered
on Jul 02, 2023
