20 Most Recent Hotpoint 24 in. HDA3740G Built-in Dishwasher Questions & Answers
cycle switch on the front is most likely bad
Hotpoint 24 in.... | Answered on Mar 12, 2019
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Hotpoint 24 in.... | Answered on Nov 04, 2010
make sure the arm on top isnt hitting something, each time you load it each in there and spin it to be sure it moves freely, also make sure your rinse agent container is full of rinse agent.
Hotpoint 24 in.... | Answered on Oct 29, 2010
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
dd
Hotpoint 24 in.... | Answered on Sep 30, 2010
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dhfgs
Hotpoint 24 in.... | Answered on Sep 29, 2010
Leaking Dishwasher
heatman101
870943q45
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Hotpoint 24 in.... | Answered on Sep 21, 2010
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Hotpoint 24 in.... | Answered on May 15, 2010
the spray arm not spining and shut water on the door all the time or the hole in the spray arm is clug
Hotpoint 24 in.... | Answered on Jan 01, 2010
Not draining the water out....
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Check to make sure which style d/w you have as outlined above. The direct drive dishwashers have a drain solenoid attached to the motor and pump or a separate drain valve that must be checked with a ohm or voltmeter. The drain solenoid and valve energize and opens the drain port to allow the water to pump out. For a "no drain" problem, always start with the common stuff first...a kinked or clogged drain hose. The drain hose must be checked and cleaned out and if you have to, remove the drain hose(s) to fully check and clean them. Don't forget the drain system sometimes consists of a self cleaning bodythat also can get clogged and stop the dishwasher from draining. If your drain hose needed to be lengthened a hose connector was probably used, these hose connectors are slightly smaller than the drain hose and food bits often get clogged there, also the tail pipe piece that connects the drain hose from your d/w to the house drain is also another popular place to get a clog. On the forward/reversing style of dishwashers that won't drain, make sure the motor is reversing to drain the water out. If the motor does not reverse to drain, the motor, wires ( especially where the doors bends to open and close ) and timer will have to be checked. If the motor is reversing and running, the pump impellor inside the motor and pump assembly may be damaged and is incapable of pushing the water out to drain. If the drain solenoid or drain valve checks ok on the direct drive motor and pump, the impellor inside may also be damaged as mentioned above.
Always check the drain spout under the sink for a d/w that will not drain, also if the Air gas is leaking ( see Fig1A ) this is a clogged air gap or drain and normally not a d/w problem. These are some typical drain hook ups....if you have a drain question, may be a good idea to refer to one of the figures so we all know which style you have :-)
click this link directly
http://www.applianceaid.com/drain_wash.html
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Hotpoint 24 in.... | Answered on Nov 26, 2009
Does water comes into the dishwasher all time, even when it doesn't operated?
Hotpoint 24 in.... | Answered on Sep 07, 2008
Hotpoint 24 in. HDA3740G Built-in Dishwasher Logo
26 questions posted
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Dishwashers
Most Popular Question
drainage problem
  • Dishwashers
