20 Most Recent
Hotpoint HTM17BBSSA Top Freezer Refrigerator Questions & Answers
Hi, my Hotpoint ff200e fridge
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
4/24/2017 10:31:29 AM •
Hotpoint...
Answered
on Apr 24, 2017
Freezer works bottom part doesnt get cold
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click for article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
7/24/2011 8:44:20 PM •
Hotpoint...
Answered
on Jul 24, 2011
Faulty Hotpoint Fridge Freezer
past rulings under the sale of goods act is that if product has lasted a year, then it is of merchantable quality - you are unlikely to get a full refund or free replacement even if you went to arbitration.
but what was wrong with it that your engineer deemed it to be uneconomic to repair?
remember that finding a good refrigeration technician is not easy
2/22/2009 11:52:15 PM •
Hotpoint...
Answered
on Feb 22, 2009
Problem with drawer configuration. I have a Hotpoint Freezer. Model FZA84.
Does the problem move with the drawer when you shuffled them or did it do the same thing in the same position? If it moved it's the drawer causing the issue, if it stayed in the same place it's the freezer itself.
Empty the offending drawer and have a good look at it. A lot of front panels on freezer drawers are a 'push on' fit so check the front is clipped on correctly on both sides. Next check the runner rails and back panel of the area that drawer goes into. It might be something as simple as a lump of ice or something stuck to the side/back or a something in the drawer above or below blocking it.
6/28/2023 5:17:16 PM •
Hotpoint...
Answered
on Jun 28, 2023
I heard some clicking noises
yes . it sounds like the main board . the clicking would be the relay that starts compressor ... change the main board .. mm feed back pls . with a model # i can give you part # & price .
5/17/2023 6:40:48 AM •
Hotpoint...
Answered
on May 17, 2023
Can you disconnect the ice maker only on a hotpoint ctx21ga refrigerater
Yes, you can disconnect the ice maker on a Hotpoint CTX21GA refrigerator. Here are the general steps to follow:
- Unplug the refrigerator from the electrical outlet or turn off the power at the circuit breaker.
- Locate the water supply line that runs from the back of the refrigerator to the ice maker. It is typically a flexible plastic or copper tube.
- Find the valve where the water supply line connects to the refrigerator. It may be located behind a panel or cover.
- Turn off the water supply to the refrigerator by closing the valve. You may need to turn it clockwise to shut it off.
- Disconnect the water supply line from the valve by loosening the compression nut or other connector.
- Locate the ice maker inside the freezer compartment. It is usually mounted on the back wall or ceiling.
- Unplug the ice maker's electrical connector by pulling it out of the socket.
- Remove any screws or mounting brackets that hold the ice maker in place and gently pull it out of the freezer compartment.
- If you wish to permanently remove the ice maker, you can disconnect the wiring harness and remove the mounting bracket.
- If you plan to reconnect the ice maker in the future, you can leave the wiring harness connected and store the ice maker in a safe place.
- Reconnect the water supply line to the valve and turn the water supply back on.
- Plug the refrigerator back in or turn the power back on at the circuit breaker.
2/21/2023 12:04:57 PM •
Hotpoint...
Answered
on Feb 21, 2023
