20 Most Recent
E-Machines (T3104) PC Desktop Questions & Answers
Cd rom wont open
On the front of your cdrom by the power button there is a small hole. Take a paperclip straighten it out slide it in that hole directly in the center and push slightly don't force the door will open when you push on the release button with the paperclip.
Terry
T3104 not recognize second hd
Make sure it's plugged in correctly, then go into Disk Management and make sure you can see/format the drive. A lot of times the disk needs to be initialized before you're able to use it.
My T3104 came with a cd burner. I upgraded it to a
If they were both working on separate machines, the answer must lie in how you have configured them on your PC.
Remember that your dvd/or cd drive would be the SECONDARY MASTER. If you have both cd drive and dvd drive set as master,this may cause your PC to not recognise them.
Look on the back of the cd drive and the dvd drive - at the small jumper switches, which fit onto pins. There will also be a diagram on the drive somewhere. Look for CSM C= cable select (let the computer choose which is which. M= Master, which means you set that particular drive as the secondary master. S- slave. You set whichever drive as the slave.
The drive on the end of the cable (furthest away from the motherboard) should be set as MASTER. Any other drive on that same cable should be set as slave.
Password Not Working
do you want that data on their old hard drive. best thing to do is format the hard drive and install fresh operating system
My slcdii file is missing, how do I retrieve it?
Its scl dll file not slc dii.1. Download, install and run DLLSuite, 2. Click Start Scan button to conduct a full scan for slc.dll as well as corresponding issues3. Locate to file slc.dll and click More Information. You will reach a web page where you can download slc.dll file.Tips: Before save slc.dll to its path, please use DLLSuite to create system restore points first as if the file path is incorrect, your system would become unstable, even crash.4. Click Start, Run and type regsvr32 slc.dll , and then press Enter.5. Restart your computerHope it works for you.Also use a sytem utility software like ReginOut to avoid such type of errors. It will optimize your PC and fix different operating system errors.
I CAN NOT FIND MY
Recommendation, just burn it now and get it over with. I have one of those worthless doorstops in the corner of my room.
Hi i recently installed windows
Ok, you need to install your audio driver which you can search here:
http://support.gateway.com/us/en/emac/product/category.aspxYou did not specify what is the model of your e-machine so just search it there.
Choose if it is a netbook, notebook or desktop... then choose which model (series) then choose the model number..
After that click on the "Drivers" tab and choose to download "Audio"
Thanks for using Fixya! Don't forget to rate =)
Have an older emachines T3104.
If you know the manufacturer of sound chip, go to their web site and get the driver.
You can look in the device manager to find the sound chip manufacturer.
Did a system restore on my computer but when it
you should start with updating the sound drivers. they get lost sometimes on restore. it wouldn't hurt to go to EMachines and update all drivers for your unit. also look at he specs for your unit, it will tell you who the sound manufacturer is and then you can go to their web site to update drivers also. if you need more info reply back
I show on monitor
Check that the "data" cable between your computer and your monitor is tightly connected at each end.
Connect the VGA-output port from a laptop computer to the monitor, to see if the monitor works when connected to a different computer.
Connect a different monitor to the VGA-output port on your computer, to see if that monitor works.
Failing all the above, the video-card on your computer is the problem, and needs to be replaced.
Lost sound--mute
Click Start > All Programs > Accessories > Entertainment > Volume Control
Make sure None Of the Boxes are Checked Mute
Emachine t3104
For doing a system recovery on E-machine you have to press F11 number of times at the very first boot screen then follow the procedure, and it will restore your computer back to the factory settings.
This option is available in new computers only. (2-3 years old)
