20 Most Recent
Magic Chef CAV2004A Top Load Washer Questions & Answers
Won't stop filling
I think you areon the right track. go to appliance parts.com and put in model it will show you where part is so you will have an idea of how to remove it
Bottom agitator works the top
The internal parts of the upper agitator have worn out and the upper agitator needs to be replaced.
Its pretty easy to do all that needs to done is remove the top cap of the agitator and remove the bolt under the cap,pull off the top agitator and install the new one and bolt it back down then snap the cap back on. The part number for top agitator is 21001521 it could be purchased at your local appliance parts store or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
appliancepartspros.com
apdepot.com
Gene
Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
What is the error code E2 for Magic Chef 2.1 cu. ft. Top Load Portable Washer?
I put this answer in the comments but re-posting here because I didn't know what I was doing : )
The Magic Chef 2.1 cu ft Portable washer manual says that its a door malfunction and the solution is to open and close the door. That did not work for me so if you're having the same issue that I am it may be that your washer is not level. I had placed mine on top of a few folded throw rugs to stifle noise (I live in an apt, on the second floor) and the rugs were uneven. As soon as i adjusted them, the washer began to work again. I hope this helps.
Agitates but does not spin at all (does drain)
Check the lid switch assembly: If the lid switch assembly is defective, the washer will not spin. To test the lid switch for continuity, use a multimeter. If the lid switch does not have continuity, replace it.
Inspect the drive belt: If the drive belt is broken or loose, the washer will not spin. Inspect the drive belt for signs of wear or damage. If the belt is damaged, replace it.
Examine the motor coupling: The motor coupling connects the motor to the transmission. If it is broken, the washer will not spin. Inspect the motor coupling for signs of wear or damage. If it is damaged, replace it.
Check the clutch assembly: The clutch assembly engages and disengages the transmission with the tub during the spin cycle. If it is worn or damaged, it may prevent the washer from spinning. Inspect the clutch assembly for signs of wear or damage and replace it if necessary.
If these troubleshooting steps do not lead to resolution, you may have to resort to a professional repair service.
10/21/2023 10:03:01 AM •
Magic Chef...
Answered
on Oct 21, 2023
Magic chef error E4
E4 indicates the washer failed to drain out after 4 minutes, after that time the code is set. Check and clean the drain filter first.
10/23/2022 12:53:29 PM •
Magic Chef...
Answered
on Oct 23, 2022
Washing machine parts where can I ordered a lid for a portable magic chef washing machine
FIXYA does not sell parts.Use the internet to search, or visit retail stores that carry that model to request assistance.Part number or at least model number is needed to search using Google.com Possibly available thru Home Depot, Walmart, online at Amazon.com, or
www.repairclinic.comhttps://www.repairclinic.com/PartDetail/Lid/WPW10193857/1456205?TLSID=1779&Ref=611198&gclid=CjwKCAiAzanuBRAZEiwA5yf4ulvClQ-c9bkG6bmkfD91ywohSLeEMqIxuQ4R7ziLpTtNgirJg3gcyxoCO7MQAvD_BwE
