20 Most Recent
Elo 15" Touch Monitor Questions & Answers
I got a ELO 1524L LCD touch monitor. The back
You should have 2 wires for 12~15 power going in, which you already indentified, 2 more wires should be for ground return, you can check for them by using Ohm meter between the chassis and probe the wire for less then one Ohm resistance. The other two wires, 1 wire will be for Dimming control (usually 0 = dimmed, 5vdc = full brightness), 1 wire will be for BACKLIGHT ON/OFF (0v= OFF, 4~5VDC = ON) control.
Dose the fuse on the inverter board check out OK? You can use other inveter board as long as the lamp connectors are the same and you just have to match the input signal pin. I have done many.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
See example of the fuse on the inverter board.
I can not hear any sound through the speakers of
The Elo ET1527L Monitor has stereo speakers. Within the OSD (On Screen Display) you can control several properties of the monitor like; brightness, contrast, positioning, color, and SOUND. See the buttons on the right side.
I recommend setting the sound to 100%. The speakers are small and weak. They are pointed to the rear, I assume for customers to hear.
The buttons do have a lock-out feature too. If they don't respond, while on, hold down the top two buttons and the screen should display Lock / Unlock. Wait until you see the one you want and then release. The power button lock out works the same way, holding top and 3rd button to lock/unlock.
The device drivers give you an option to use internal (monitor beeps) and external (PC port) sound sources.
Touchscreen calibration
does lightly swiping your finger across the screen from the bottom left corner across to the upper right corner? there are different swiping motions that perform commands.
Como cancelar el winter driver
Question translated to English
Solo hablamos ingl?s en el sitio web norteamericano. Lamentablemente no tenemos idea de qui?n es este conductor de invierno. Por favor danos m?s informaci?n para ayudarte mejor. Es un problema de seguro de autom?vil, debe comunicarse directamente con la compa??a de seguros.
ENGLISH@
We only speak English on the North American website. Unfortunately we have no idea who this winter driver is. Please give us some more information to help you better. It is is a car insurance issue, you need to contact the insurance company direct.
