20 Most Recent Digital Blue QX5 Microscope Questions & Answers
Drivers ds 300 osx+pc
Always, without exception, use manufacturer supplied software. Otherwise you may be introducing Trojan or other nasty viruses to your computer.
12/31/2023 7:19:54 AM • Digital Blue QX5... • Answered on Dec 31, 2023
2answers
Error 102 microscope not plugged in
One has to have a compatible operating system with the correct driver, Your computer operating system must be set for reading the USB port as a video device, f you are able to read any data from the scope you should also check firmware version against the manufacturer's latest revision. Also suggest you download the operator's manual from the manufacturer's site.
2/3/2018 11:11:41 PM • Digital Blue QX5... • Answered on Feb 03, 2018
Downloadable software
This link should provide you the manual as a pdf file
http://digiblue.com/customer-service/downloads/qsg/DigiBlue_QX5_QSG.pdf
10/17/2017 9:10:30 PM • Digital Blue QX5... • Answered on Oct 17, 2017
How do you set it up
Downloads and install the appropriate driver software from Digital Blue:
QX5/Smithsonian Computer Microscope Drivers for WIN ME, 2000, XP, Vista 32-Bit
Download Drivers
QX5 V2 Computer Microscope Drivers for Windows Vista 64-Bit
Download for Windows Vista 64-Bit
QX5 V2 Computer Microscope Drivers for Windows 7
Download Windows 7 32-Bit
Download Windows 7 64-Bit
QX3, QX5 V1, QX5 V2 Computer Microscope for Mac OSX 10.4-10.6
Visit Webpage for Download
2/12/2017 8:16:50 PM • Digital Blue QX5... • Answered on Feb 12, 2017
Digital Blue QX5 Microscope software
The downloads for the QX5 are located here: Driver Downloads http://www.digiblue.com/pages/Downloads.html
2/18/2016 9:39:42 AM • Digital Blue QX5... • Answered on Feb 18, 2016
Qx 3 install windows 7 64bit
Sorry, the QX3 does not work on 64-bit systems. The drivers are not compatible. There are instructions available for using the QX3 with Windows 98, Me, XP and 32-bit versions of Vista, Windows 7 and even Windows 8.
8/11/2014 12:36:58 AM • Digital Blue QX5... • Answered on Aug 11, 2014
2answers
Qx5 is not responding
the microscope may be trying to draw too much current from your USB ports, your computer will disable the device if it does this. When this happens one of the easiest (and cheapest) solutions is to acquire a Powered USB Hub (with it's own Plug top power supply). This should aleviate any extraneous current draw to the Power supply.
8/11/2014 12:33:42 AM • Digital Blue QX5... • Answered on Aug 11, 2014
Is the software downloadable on the Internet
The drivers can be found here...
http://digiblue.com/customer-service/downloads/drivers/QX5.zip
3/30/2013 3:16:09 PM • Digital Blue QX5... • Answered on Mar 30, 2013
We lost them!)))
Here are the links to the available downloads from Digital Blue:
Download Drivers
QX5 Computer Microscope V1 Video Codecs for 32 bit versions of Vista/Windows 7
Download Codecs
7/24/2012 5:51:17 PM • Digital Blue QX5... • Answered on Jul 24, 2012
0answers
You can download the latest Windows 7 64-bit software for the QX5 from DigiBlue:http://www.digiblue.com/pages/Downloads.htmlNote, this will not work with the QX3 microscope.
2/2/2012 4:04:38 AM • Digital Blue QX5... • Answered on Feb 02, 2012
I didn't get any software with my QX5 digital
Download Drivers
7/24/2011 9:38:44 PM • Digital Blue QX5... • Answered on Jul 24, 2011
Have bought a second hand qx5 with no
The Quick Start Guide can be downloaded here:
Download Drivers
7/24/2011 9:37:51 PM • Digital Blue QX5... • Answered on Jul 24, 2011
I need the software for the QX5. Is there a spot
Download Drivers
7/24/2011 9:33:21 PM • Digital Blue QX5... • Answered on Jul 24, 2011
Does not work with windows
Check to see if your computer is running the 32- or 64-bit version of Windows 7. Then download the appropriate driver from Digital Blue:
7/24/2011 9:30:51 PM • Digital Blue QX5... • Answered on Jul 24, 2011
I need the softw for microscope qx5, i am of
Download Drivers
7/24/2011 9:29:07 PM • Digital Blue QX5... • Answered on Jul 24, 2011
109 error message when running
According to the Digital Blue website, there are a variety of things that can cause this error, including USB configuration issues, QX5 connectivity problems, or an improperly installed device. To troubleshoot, try the following steps. If one does not work, try the next until the problem is resolved.
1. Exit from the application, unplug the QX5 from your computer, and restart your computer. Once your computer has rebooted, plug in the microscope and restart the application.
2. If you are using a USB hub (an external device that allows you to connect additional USB products to your computer), exit the application and plug the microscope directly into the USB port on your computer. If the microscope works when plugged directly into your computer, there may be a problem with your hub, or it may not be supplying enough power to run the microscope. If your hub does not have a power adapter, you will need to plug the QX5 into your computer's USB port or use a hub that is powered.
3. If you are not using a USB hub, try different USB ports. Always exit the application, unplug the QX5, and then plug into a new USB port. Wait at least one full minute to make certain that Windows recognizes the QX5. Then start the application again. If you are still experiencing the problem, try another USB device (if possible). If no USB devices are working, there is a chance your USB ports are not working properly and you should contact your computer manufacturer to resolve the problem.
4. If you have a laptop, make sure the laptop is using its power adapter. When running on battery, some laptop computers don't supply enough power to USB ports and as a result the QX5 will not work properly.
Note: The following steps require some experience with Windows computers. If you are comfortable modifying advanced settings on your computer (like the Device Manager or BIOS), proceed at your own risk. Otherwise, respond to this email and provide your phone number so a member of our technical support team can assist you.
5. Plug in the QX5. Go to Start > Settings > Control Panel and double click on the System icon. For each of the following items (if present), select that item, then click the Remove button:
  • Any devices that have a ? or ! next to them, or that are listed as "USB Camera Device."
  • The driver named "Digital Blue QX5™ Microscope #2" (located under Imaging devices).
After removing all the devices, click the Refresh button.
6. Try lowering the hardware acceleration of your video adapter. To do this, follow the steps below that apply to your operating system:
If using Windows 98, Windows 98 Second Edition, or Windows Me:
  1. Click on Start > Settings > Control Panel.
  2. Double-click on Display.
  3. Click on the Settings tab
  4. Click on the button labeled Advanced
  5. Click on the Performance tab
  6. -proceed to 'fix continued...
If using Windows 2000 or Windows XP (classic view):
  5. Click on the Troubleshoot tab
If using Windows XP (XP style category view):
  1. Click on Start > Control Panel
  2. Click Appearance and Themes
  3. Click Display
  4. Click on the Settings tab
  5. Click on the button labeled Advanced
  6. Click on the Troubleshoot tab
  7. -proceed to 'fix continued...
...'fix continued'
While in the Performance tab, move the slider for Graphics Hardware acceleration one notch to the left. After you do this, the panel should indicate "basic accelerator function". Click OK, then click OK again to exit from the Display Properties window. Restart your computer and launch the QX5 software. If this does not fix the problem, repeat the process until all the available HW acceleration settings have been tried. (Different video adapters disable the acceleration at different points on the slider.)
7. Unplug your QX5 microscope and restart your computer in "Safe Mode." To get into "Safe Mode," you must reboot your computer and press the appropriate key before the Windows logo screen appears. If you do not know how to do this refer to your computer's manual or contact your computer manufacturer.
If you are successful in starting in Safe Mode, there will be a "Safe Mode" logo in each corner of your desktop. Then follow these steps:
a. Click Start/Settings/Control Panel.
b. Double-click the System icon.
c. Go to the Device Manager tab.
d. For each of the following items (if present), highlight the item, then click the Remove button:
  • Any device that has a ? or ! next it or is listed as "USB Camera Device."
  • The "Digital Blue QX5(tm) Microscope #2" driver (located under Imaging Devices).
e. Close the device manager, and restart your computer
f. Go to Start/Settings/Control Panel and double click the Add New Hardware icon.
Go through the Add New Hardware Wizard. When the Wizard asks if you want Windows to search for new hardware, select "Yes".
Note: You may be asked to insert your Windows CD or the CD that came with the microscope. If you are prompted to insert one of these CDs, you MUST do so or the microscope will not be properly installed. (Contact your computer manufacturer if you cannot find your Windows CD.)
g. When the new hardware installation is complete, restart your system, then try running the QX5 software again. 8. Uninstall the QX5 software (which will not delete any video or images you may have captured as long as you re-install to the same directory) by following these steps:
a. From the start menu, open the QX5 program group and select the uninstaller.
b. Follow the instructions to uninstall.
c. Restart your computer.
d. Insert your QX5 CD-ROM and follow the install instructions.
e. Plug in your QX5, wait a minute for Windows to recognize and install.
f. Start the application.
7/24/2011 9:26:31 PM • Digital Blue QX5... • Answered on Jul 24, 2011
Digital Blue QX5 Microscope Logo
80 questions posted
Top Digital Blue Science & Laboratory Experts
ADMIN Eric
ADMIN Eric
Allan Kipyego
Allan Kipyego
Level 1 Expert
Collins Mccoy
Collins Mccoy
Are you a Digital Blue Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Digital Blue Science & Laboratory
Most Popular Question
need softw microscope qx5 am
  • Science & Laboratory
