20 Most Recent
Envision EN7410 17" LCD Monitor Questions & Answers
Need to remove monitor stand
should be four screws holding it on. Take them off and keep them safe. The monitor is made to take this off and mount to a VESA square block plate for wall-mount etc.. look and you will see them there.
Installaion software download
You don't need software for the monitor. Windows will see the monitor automatically. Any video adjustment comes from the video adapter software
Would this monitor be covered
The warranty is 36 months parts and labor. If you have and the monitor longer than that it will not be covered. If you have had it less time than that, you can normally get a copy of the receipt from the place of purchase (example Best Buy). If you purchased an extended warranty from vendor (example Best Buy), you should be able to take it back to them for repair or replacement.I hope this helps
Envision EN7410e monitor
Just fixed mine. Maybe it's a few years late. Hope you guys still have the display. It's the power supply board. I've just replaced 4 bulge capacitors near one edge of the PS. They are 2x1000uF 10V, 1x470uF 25V & 1x470 10V. I salvaged my parts from an old CRT monitor. Hey you can go green with your repairs too!
The screen stays on a real short time then goes
The problem is in the power supply board usually caused by bad capacitors, they often bulge at the top and become open or near open, but regardless they must be changed with high temperature low ESR replacements.
My monitor keeps blinking on and off. Any idea how
Connect it to a different notebook or desktop computer.
If it still exhibits the problem, it's broken.
Given that it's only 17 inches, it may be more expensive to REPAIR it
than it would be to REPLACE it (and upgrade to 19 inches).
Take it to a qualified technician, and get an estimate of the repair-cost.
Hopefully, the technician will not charge $25 as an "inspection" fee.
En7410e turns on but wont stay on
The problem you have is caused by one of two things,
either a blown power supply in the backlight inverter or bad backlight
bulbs. More than likely it is the bad power supply. The problem in the
power supply are parts called capacitors, they blow out because of the
heat trapped inside the monitor enclosure. If you can solder you should
be able to repair this type of problem. You can go to our web site at:
www.ccl-la.com/badcaps.htm
we have pictures of what the capacitors look like when they blow out.
Take the case off the back of your monitor and look for any that look
like the pictures. Replace all of the ones that are bad, the values of
the caps are printed on the side of each one. You can order replacement
caps from several places on the internet or contact us and we can
supply them for you. When installing the replacement caps be sure to
insert the new ones with the stripe on the side going the same way. If
you don't want to do the repairs yourself we offer a repair service. If
you have any additional questions just email me.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Pulsating screen.
Due to the flourescent lights that are used in this product, i would suggest trying to return the product for a new one, as one or maybe a few of the bulbs may have busted or become loose due to the impact caused by the fall.
En7410 won't turn on
DONT WASTE YOUR TIME AND MONEY THE PCB(POWER CONTROL BOARD IS BAD YOU WILL BE BETTER OFF BUYING A NEW MONITOR)
IF you do find the power control board replacement and get it to work i think you would have better results spending the same amount of money on a new monitor with all new parts plus warranty
How can I adjust color on my main Envision 22" computer monitor I am visually impaired. There are buttons on bottom numbered 1 down up 2 and turn off.
When I press # 1 it is Main Menu.
Press windows key + r key and type control panel and press enter Or click start windows button then type control panel under the search program of files then press enter.
Once your in control panel look for the display icon and click it, and on the left pane of the screen you can see there is a calibrate color click it. Simply click next button, click next button again, click next button again, click next button again, click next button again, click next button again, click next button again, click next button again, click next button again, now slide the red, blue and green color to the max settings. Then click finish button, after it will prompt your screen about clear type tuner, still just click next, next button to finish. Have a great day.
5/21/2020 1:45:08 AM •
Envision...
Answered
on May 21, 2020
