20 Most Recent
Candy 24 in. CD622 Free-standing Dishwasher Questions & Answers
Why does my dishwasher trip our electric when we
There can be a possible short or an electrical leak- if ELCB is used- that seems to trip off the circuit. this can be a short in the main control panel which is the power section.
the ideal way to go about is to ISOLATE the circuit , so remove the control boarrd leads and check, then remove the outputs from the control board, check for leak from the board which will confirm the case.
Take precaution when checking with live circuit.
It wont drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems -
Water willnot drain out
heatman101
Candy nova cd112 dishwasher fills with water then stops working
nova cd112 this is a simple fix the machine has a electronic switch to add water to the machine it then has another switch to say the machine has water iin it , this switch is the one that is not working this is the one that turns on the element and heat the water .it costs around a tenner to replace u can find it as it is connected to the element via a wire conection .this a a common problem of over enginearing as this switch is not needed and is not on older machine .ie this switch can only come on when the machine has water in it in other words only after the switch to put water in the machine has been on.can this go on i hope u know what i mean lol. now u can replace this yourself or get an engineer it should take an engineer no more than 10/15 mins to fix better still have him bypass this switch and u will never haver the problem again as this switch is prone to going fixthis and the machine should last years no problem as its not a bad machine not quite a bosch but better than a zanussi or indicit etc hope this helps and may i just say that i tried everything including replacing the element ,stat and cpu non of which worked before realizing it was this .i must also say before u try this. Switch on your machine on put it on a universal cycle as u hear the water going in the machine open the door and add hot water as hot as u can close the door and the machine should do a full cycle including emptying and reheating the water this proves its not the cpu ,element or stat note the machine will not do the cycle without the hot water going in at the start if it does the cycle then its 100 % this switch hope this helps and sorry for the lond explantion bye
Wont empty
Water will not drain out
heatman101
Hi my dishwasher leaks water all over the floor
Take of the side panal right side facing the front as this exposes more of the bottom of the machine. Check for any leaks around the pipes and the sump. While side is of turn machine on and see if you can spot any water and make note where abouts in the wash it is as this will point you to where leak will be.
Can i use my candy
I strongly advice against it, because the pumps are gonna assume thier is water their and is gonna try to pump the water in, and u will burn them up if their is no water their.. how ever you could get a splitter and run water to both hoses. even though their is no hot water you could run it. just need water going to both lines. your dishes how ever wont get as clean as they would if you had the hot water.
please rate this
