20 Most Recent
Impression Products Impression 9LSP 19" LCD Monitor w/ Speakers Questions & Answers
MONITOR IS BLACK, POWER LITE IS ON, I CAN HEAR COMPUTER SOUNDS
By computer sounds do you mean the sound of fans and hard drives spinning? If there are no loud distinct beeps indicating a startup error (See
Post Beep Codes), then I would check the following.I'm assuming you mean the power light on the monitor is on. If that is the case then it is one of two things.
- The monitor is not set to the correct input source.
- Make sure you go through the monitors menu and select the input. Example
- The video cable to the monitor has a bad connection.
- Make sure the cable is connected properly
- If repositioning the cable differently restores the image than the cable is most likely failing. Try replacing the cable with known good one.
- If the cable is good it could be a problem in the jack on the monitor or the computer.To repair this would require disassembling the monitor or computer and replacing the jack.However, most computers and monitor have more than one type video input/output. Try the other input/output jacks. Example
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
Is there any one here know B**** food equipment? I have question about this company?
As you are Anonymous, it would seem like this is a veiled advert to get the company name promoted.The company is in British Columbia, Canada. What is your concern? I am in Ontario and have had a 50 years career in catering.Finding them is easy, reviews are goodRahmalek "Very good service, best prices in town."Mikey "Great customer service, reasonable service fees and on time all the time."salek "Great experience working with B***** FOOD equipment. excellent customer service."..
I want to search job
www.jobstreet.com www.workabroad.com good luck in finding the right job for you.
