20 Most Recent Jet Tech Systems X-35C Dishwasher Questions & Answers
If water keeps running even if the unit is unplugged than the water solenoid valve has become defective.
if the water stops when power is off than there is a problem with either the timer or the fill switch. My bet is on the timer.
Always be careful when opening the top cover. you will be exposing wires. power must be turned off at the breaker or the unit unplugged.
Jet Tech Systems... | Answered on Jul 15, 2014
a plug can be warm. if it is hot to the touch, stop using it and have the machine checked and the receptacle check by a qualified technician.
Jet Tech Systems... | Answered on Sep 02, 2014
for models equipped with a drain pump;
verify that the pump is not clogged. if it hums during the fill cycle or rinse cycle then something is lodged inside. If it doesn't then it needs to be replaced.
for models without the drain pump;
something is interfering with the water flow. when the stand pipe is removed, the tank should empty in about one minute.
Most Jet-Tech dishwashers has one adjustable rinse thermostat and one fixed wash thermostat. The wash thermostat can be substituted with an adjustable thermostat. Location depends on the model. F-18 are located on top. F-22 are located under next to the wash tank. Search by part number or description
On the F-14, the booster thermostat must be satisfied. The rinse thermostat must work properly and or the rinse heater. follow the diagram. This kind of troubleshooting is done by qualified technician. Remember to unplug the unit before opening the panels. It could be just a burnt wire on the rinse booster heater connection.
The detergent system on the Jet-Tech machine are all very similar. Near the solenoid valve under the machine, beside the drain connection, there are two wires, one red and one blue. Those wire will run the detergent pump when the machine calls for water. Two tube are attached to the pump. when looking at the pump from the front or clear plastic can be seen, the tube on the left (arrow going up) is connected to the container with the detergent. the tube on the right (arrow down) is connected to the back of the unit to inject the detergent into the tank. Some precaution should be taken to assure that the connections are tight and not leaking. if the tube shows signs of crystals inside, it should be replaced as the detergent as crystallized within. Search by part number or description
If the machine will fill on its own when it is empty then the rinse cam on the timer is defective
Jet Tech Systems... | Answered on Dec 29, 2013
No idea as i would either make my own or go to general store in alicante and ask the nice man if he has anything that would do the job if the original parts were not available
Jet Tech Systems... | Answered on Dec 25, 2011
www.jet-tech.com/products/F-18DP/f18_tech_manual.pdf
Copy and paste that link into your internet address bar or type it in.
That is your manual
Jet Tech Systems... | Answered on Sep 22, 2010
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jet Tech Systems... | Answered on Sep 01, 2010
If this is a common problem then ring the manufacturer, if not you will need to have it replaced.
Jet Tech Systems... | Answered on Aug 03, 2010
Diabex is a medicine that helps keep the body in good shape, but there is no insulin in it. You need completely different medicines. I know a site where you can buy cheap drugs with bitcoin using https://directdrugs.to/ this online drugstore. Also there you will find all the necessary information. But first of all, my advice to you, talk to the doctor.
Dishwashers | Answered 19 hours ago
I had the same error. Unplugged it. No help. What I did that fixed it was to hold the start/pause button down for 3 secs. This then started the machine's cycle where it had been before the error. In my case about 30secs before the actual end.
I think the eroor was caused by opening the machine before it had actually finished it's cycle.
Dishwashers | Answered Yesterday
Depends on the type of washer/seal on the coupling. If it's rubber, or rubber type material, then you shouldn't really be able to turn it once the coupling is tightened. However, if it is a ptfe/firm plastic then it MAY be possible to move it with some force.
Firstly, ensure that you do have a washer in the coupling. Sometimes they stick to the appliance when being dismantled, and may fall off when being moved.
I would recommend tightening firmly by hand (those with gorilla hands need not apply). Then turn on the isolating valve on the supply, and monitor the coupling for a few minutes. If you see water appear, you know what to do! Tighten it up some more.
Good luck.
D
since i see no brand or make mentioned , I could never begin to guess suggest you call a local repair service
Dishwashers | Answered on Apr 20, 2019
Dishwashers Logo
1 questions posted
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Jet Tech Systems Dishwashers
Most Popular Question
water will not shut off after starting
  • Dishwashers
