20 Most Recent Jet Tech Systems CHALLENGER Dishwasher Questions & Answers
Be sure you don't have "economy mode" turned on.
Jet Tech Systems... | Answered on Mar 07, 2016
a plug can be warm. if it is hot to the touch, stop using it and have the machine checked and the receptacle check by a qualified technician.
Jet Tech Systems... | Answered on Sep 02, 2014
for models equipped with a drain pump;
verify that the pump is not clogged. if it hums during the fill cycle or rinse cycle then something is lodged inside. If it doesn't then it needs to be replaced.
for models without the drain pump;
something is interfering with the water flow. when the stand pipe is removed, the tank should empty in about one minute.
Most Jet-Tech dishwashers has one adjustable rinse thermostat and one fixed wash thermostat. The wash thermostat can be substituted with an adjustable thermostat. Location depends on the model. F-18 are located on top. F-22 are located under next to the wash tank. Search by part number or description
Jet Tech Systems... | Answered on Jul 15, 2014
On the F-14, the booster thermostat must be satisfied. The rinse thermostat must work properly and or the rinse heater. follow the diagram. This kind of troubleshooting is done by qualified technician. Remember to unplug the unit before opening the panels. It could be just a burnt wire on the rinse booster heater connection.
The detergent system on the Jet-Tech machine are all very similar. Near the solenoid valve under the machine, beside the drain connection, there are two wires, one red and one blue. Those wire will run the detergent pump when the machine calls for water. Two tube are attached to the pump. when looking at the pump from the front or clear plastic can be seen, the tube on the left (arrow going up) is connected to the container with the detergent. the tube on the right (arrow down) is connected to the back of the unit to inject the detergent into the tank. Some precaution should be taken to assure that the connections are tight and not leaking. if the tube shows signs of crystals inside, it should be replaced as the detergent as crystallized within. Search by part number or description
If the machine will fill on its own when it is empty then the rinse cam on the timer is defective
Jet Tech Systems... | Answered on Dec 29, 2013
No idea as i would either make my own or go to general store in alicante and ask the nice man if he has anything that would do the job if the original parts were not available
Jet Tech Systems... | Answered on Dec 25, 2011
www.jet-tech.com/products/F-18DP/f18_tech_manual.pdf
Copy and paste that link into your internet address bar or type it in.
That is your manual
Jet Tech Systems... | Answered on Sep 22, 2010
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jet Tech Systems... | Answered on Sep 01, 2010
If this is a common problem then ring the manufacturer, if not you will need to have it replaced.
Jet Tech Systems... | Answered on Aug 03, 2010
Tip
How to find appliance model numbers
<p>When trying to troubleshoot or purchasing parts for your appliance the model number is the key to doing so. Each model may have different part numbers and or different troubleshooting techniques. They may also have a different service manual. The model number that is on your customer manual is just a generic copy of many models that exist and can not be used for the information that is needed.<br /> <p>Below you will find a video procedure that will show you how to find your entire model number. You can bring it up in either picture or video format.<br /> <p>For finding your appliance model number Click on the link <a href="http://www.repairclinic.com/Appliance-Parts">http://www.repairclinic.com/Appliance-Parts</a><br /> <p>Just to the right of the "<b><i><u>search</u></i></b>" tab click on "<b><i><u><span>help me find my model number</span></u></i></b>"<br /> <p>Just click on the model of your choice In either video or image<span> </span>presentation<br /> <p>Please consider giving us a 4 thumbs up for our procedure.<br /> <p> <b><i><u>Thank you for using FixYa!</u></i></b><br /> <p> <br /> <p><img src="kdrake84_0.jpg" /> <img src="kdrake84_1.jpg" /><br /> <p> <br /> <p><span></SPAN><span><br></SPAN> <p>
Yesterday | Dishwashers
That is a water inlet fault. If the tap under the sink is turned on and everything else seems OK then the inlet hose/valve will need to be replaced by a technician
Dishwashers | Answered on Apr 13, 2019
That is not found as an error code in the user manual. The manual says to call customer care if a symbol pops up that is not listed in the manual. This is a Westinghouse dishwasher serviced by Electrolux. Here is a page which may be of assistance in contracting Electrolux.
https://www.electrolux.com.au/support/service-centre-locator
Here is a troubleshooting page (but it does not identify the code):
https://www.repairclinic.com/RepairHelp/Dishwasher-Repair/9-89--/Westinghouse-Dishwasher-Troubleshooting
Here is the user manual:
https://manuals.appliancesonline.com.au/sb916sl/sb916sl.pdf
You might in the comment file add what the P stands for if you contact Electrolux. I do not find an explanation on the web.
Well, this was very long-winded. If it works when filled manually, then check the stopcock for the water flow and open it more if not all the way. If this does not work, try the water pump in the back/bottom of the disher
Dishwashers | Answered on Apr 12, 2019
Jet Tech Systems CHALLENGER Dishwasher Logo
Popular Tags
1 questions posted
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Jet Tech Systems Dishwashers
Most Popular Question
dishwasher not dry
  • Dishwashers
