20 Most Recent Candy AQ130 Front Load Washer Questions & Answers
no, the tumble dryer has nothing to do with it. My family always complain about our hard towels. Recently our front loader broke down & I had to hire a top loader til it was fixed - my towels became luxiously soft after just a few washes in it! I think it is how much more the washing is spun out. I am going to try to reduce the front loader spin speed when I get mine back. I never use a dryer on towels - takes too long.
Candy AQ130... | Answered on May 23, 2017
Not filled in preset time allowed - washing machine does not fill
·Check mains water pressure
·Check inlet hoses for kinks
·Check inlet filter
·Check water inlet valve
·Pressure switch fault
Wiring fault
Candy AQ130... | Answered on Dec 22, 2015
Not drained in time allowed - washing machine fails to drain water
·Check that filter is not blocked or obstructed
·Check drain hose is clear of any blockage or obstruction
·Check wiring to drain pump
·Check drain pump is not defective
·Check level sensor or switch
Check wiring to level sensor
Multiple instances of anti-flood contacts in pressure switch being made
·Check for overfoaming evidence - can trip pressure switch
·Check wiring to level sensor
·Check pressure switch is not defective
Water inlet valve locked open
something is blocking the box going back in
check for bits of metal {metal wires} parts from games and toys
like lego bricks or a coin or something
Candy AQ130... | Answered on Nov 28, 2014
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Candy AQ130... | Answered on Mar 27, 2014
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
Candy AQ130... | Answered on Jul 30, 2013
Could be a faulty valve solenoid. Pump works but outlet closed. The pumps rarely fail to pump, they usually leak.
Candy AQ130... | Answered on May 07, 2012
The most likely cause is a failed water inlet solenoid valve.
Disconnect the water and electricity supplies and undo the screws at the rear of the machine to remove the lid. The faulty part is the one with a couple of wires leading to it and a hose coming from it immediately behind where the flexible hose connects to the back of the machine.
The part can be removed quickly and easily using a screwdriver set and pliers and is not expensive nor hard to get as it's common to many other models.
After replacing the unit, make absolutely sure that the joint is completely watertight before you reconnect the power supply. Also the supply hose has a swealing washer at both ends, and ideally they should be replaced and not re-used, they cost pennies and you can get them from the same place you buy the new valve from.
Candy AQ130... | Answered on Jul 01, 2011
Hello & Welcome to FixYa
You can start with cleaning the drain filter pump assembly located inside the front bottom panel of the washer. After it's cleaned and the problem is back then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Candy AQ130... | Answered on Jun 19, 2011
If you are having dryer problems and you cannot even get the thing to start, then you might want to start going through this check list of possibilities. There are a number of things that can cause your dryer to not run.
A couple of the most common problems are the thermal fuse has blown or the door switch is not operating properly. On many dryers if the thermal fuse blows, the dryer will not run at all. This fuse can be checked with an ohm meter. It should show continuity if it is okay. If there is no continuity then you need to replace it and also find out what else failed. This is a safety device that usually blows because something else allowed the dryer to get too hot. It is usually located in the back of the dryer, on the blower housing. Some are oval in shape and others are rectangular, usually with two wires attached.
A defective door switch or a bent door switch lever can also cause you to have problems. If the lever is broken or bent it will not activate the switch. If the switch is broken, this also will not allow the dryer to be started.
The push (or turn) to start switch can go bad, but is unlikely. To check this, hold it in or turn it and then check to make sure you have continuity with an ohm meter.
If the dryer starts and then stops when the switch is released check the control board or the ?even heat? control on some model dryers. Some dryers have a belt break switch that can fail or your belt may be way loose or broken.
Check for burn marks or burnt wires at the terminal block on your dryer, poor connections can cause all kinds of problems. Also poor connections can cause fires.
A bad power cord also falls into this same category.
Of course, always check that you have the proper voltage to the outlet that you are plugging into.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Candy AQ130... | Answered on Jun 06, 2011
Quick answer-
From whichever spares company you are purchasing your replacement belt should know if you tell them the make and model number and they should supply the correct one ;-0)
(I'm doubtful, now, of wishing you 'good luck' but I will!)
Good luck,
John C
Candy AQ130... | Answered on Mar 03, 2011
remove the pump, sounds like its blocked up in the tubes happens all the time with mine
Candy AQ130... | Answered on Feb 13, 2011
Candy AQ130 Front Load Washer Logo
60 questions posted
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Candy Washing Machines
Most Popular Question
towels all come out hard rough
  • Washing Machines
