20 Most Recent
Akai PDP-5016H 50 in. HD-Ready Plasma Television Questions & Answers
No display r sound
I can tell you exactly which 3 dollar part to replace . But i put my time into my education and if i just tell you for free my kids will go hungry.
Tv background noise
Try by resetting the picture settings. Brightness, contrast etc. Do a factory reset. Refer its user manual for details.
I have an AKAI PDP
Hello
Your suspection may be correct. But this type of fault will occur due to faulty system memory IC too. First replace it. Then proceed. It seems you to be a well experienced technician. Replace the EEPROM first. OK.
Is there an spdif plug
Sorry - no digital audio input / outputs (spdif, optical, coaxial, etc.) on this TV. Standard analog "RCA" type audio connections only.
AV Input & Output RCA Terminals
S-Video Input Mini Din 4 Pin Terminal
1 Set of Left and Right Stereo RCA Terminals:
Audio Input for D-Sub 15 Pin & DVI Connector
Audio Input for S-Video
Audio Input for YCbCr
Audio Input for YPbPr
I hope this helps. Please rate my reply - thank you.
I just bought a blu
If you have it plugged into the dvi that most likely is the highest resolution 1024x768.
Thank you,
Lee
Akai pdp5016h....turns on with main power switch,
Does the screen turn on momentarily before it goes into standby mode? Do you hear clicking noise before it goes into standby? Please answer these questions so that I can help you with your problem.
Sai.
Akai lct 2715 the power
Hi
Thanks for using FixYa. This light means that the power is getting to the unit however, as its not working which means that the power board should be checked. To start with open the back of the unit and then check the power supply board for any bad (bulged/swollen) capacitors. Power supply board is the board where all the power cords/plugs goes into. After you have checked that also check the main board and if you can use a multimeter to test the components on these boards. All this should only be done if you have knowledge of internal circuitry of the unit as the components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
When i turn it on their is nothing just the light
The flashing red light is an error code to diagnose what is wrong with it. Turn off the TV and then turn it back on and count the series of flashes, make a note of it, and re-post with that number along with the rest of your TVs information again. It is the beginning of the repair process.
I hope this helps and good luck!
My TV reboots at any giving time.. Most of the
Hi
Thanks
for using FixYa. A plasma TV is a very hard working device. It is
working harder than any TV that has been built before, and as a result it
produces a lot of heat. 75% of technical problems in plasma TV's are caused by
overheating problems. X, Y sustain, buffer boards controls
picture, fires the gas, and many others functions. When either of these boards goes
bad common problems include negative image, no image, vertical or horizontal
stripes on picture, turns on and than turns off, and many more. You’ll need to
open the back off the TV and check for any swollen/bulged/leaky capacitors on these
boards and replace whichever has gone bad. All this is only recommended if you
have electrical expertise & know how to solder/re-solder components as these
units contain high voltages even when switched off.
Please do
accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
