20 Most Recent Lite On SHD-16P1S Internal DVD Drive Questions & Answers
2answers
My dvd player used to work now it doesn't even
Hi Maverick,
Can you get to device manager to see if your drive is installed and recognized by the system.
In windows 7/vista click start and type in 'device manager' in XP click start -> right cick on My computer and select properties and navigate to the device manger tab.
There will be a list of hardware installed in the list and you should find your drive under DVD/CD ROM drives. If there is a yellow exclamation mark - you need to update the drivers using the CD that came with the drive.
If the drive is not showing up in device manager you need to take your comp to a service center as there may be a fault with the controller.
Rhino.
3/5/2011 4:01:40 AM • Lite On... • Answered on Mar 05, 2011
2answers
My dvd doesnt have drivers it used to work now
You should be able to download the correct drivers for it here.
3/5/2011 3:02:08 AM • Lite On... • Answered on Mar 05, 2011
Why i cant burn an
uninstall nero and try to seek drivers for that on these page: ninite.com you can find alot of installer there that you will need in that problem
2/9/2011 1:09:05 PM • Lite On... • Answered on Feb 09, 2011
Tray won't open and if you hit the button enough
This DVD drive has a small processor in it. The button sends a signal to the processor to open the door. The processor then turns the light on and the door is supposed to open.
This unit is broken and needs to go to a shop as the IC that opens the door is probably bad.
Try this: get a paper clip and find the small hole in the door. This will manually open the door. Then use the button to close it. It could also be a mechanical failure..
4/4/2010 7:49:16 PM • Lite On... • Answered on Apr 04, 2010
Can't read dvd after flashing with gs07 firmware
you may have no problem with the firmware, you may have some optical problem. you may try replacing a new optical drive. it will save you more time. hope this helps
2/4/2010 5:27:02 AM • Lite On... • Answered on Feb 04, 2010
P4B533 doesn't load up windows. reset BIOS,swap memory. Green lite on MB, CPU fan runs. long beep
1. check for keyboard stuck keys. 2. Clean memory and Memory slot well and fix back memory. 3. check capacitors close to the memory slot if they are not damaged, if damaged replace the capacitor with a new capacitor.
8/13/2022 2:07:04 PM • Lite On... • Answered on Aug 13, 2022
2answers
Driver missing for lite-combo sohc-4836k
please will you till me vinaly AC97 ADIO CODE 10 IS NOT INSTALL HOW CAN I UPDATE THIS DRIVE
5/15/2022 1:06:51 PM • Lite On... • Answered on May 15, 2022
I want to move old HDD drive from broken down LiteOn 5045A DVD recorder to replacement DVD recorder machine...
cart before horse.!WELL BAD NEWS (TOPIC) HDD.the drive is 21 years old tech. 2001it is not any kind of modern standard HDDit is PATA(IDE) NOT MODERN SATA (SERIAL ATA)SO ONLY RELIC OLD DRIVES CAN WORK HERE.or run old 20+ hdd tests that take a week to finish(now you see why SATA was born, PATA stinks)and worst is the DVD burner is not a desktop or laptop standard drive and worse yet PATA againthe old DVD drive, replacement can be hard.lite-on does not support old things, gee most makers do not after 17 year old.also read here, and see how spare parts actually workin this old burner systemhttps://forum.videohelp.com/threads/325208-Liteon-LVW-5045-replace-DVD-drive-project-startedwhat your are attempting is not easythe huge problem is fireware in the devicemany not allow larger HDD over 160GB new.or may not allow all makers of the drive to work at all.is not that DVD DRIVE, PATA DRIVE, NOW 100% OBSOLETETHE SAME FIRMWARE RESTRICTIONS (NOT DOCUMENTED ON EARTH i MIGHT ADD) WILL NOT ALLOW SOME DVD DRIVES BY OTHER MAKES.... LOOKING NOW AT OTHER WORKING ON THIS OLD BEAST WHAT DO I SEE IN their nice PHOTOSL (tech eyes win)the hdd iS NOT SATA IT IS 20 YEAR OLD PATA(IDE) JUNK.FINDING GOOD USED PATA DRIVES IS HARD..NEW ONES ARE SOLD AT SCAPLERS PRICES, (AS expected)the DVD drive is clearly custom made by SONy for Liteon..HERE IS DVD PROOF OF NON STANDARD DRIVE(FIT)45ad81af-aef0-4368-8bdf-55959c725f31.jpg
5/15/2022 11:40:43 AM • Lite On... • Answered on May 15, 2022
I have a zipspin c120 pro, the Lite-on ihap 122 drive is bad, will a ihap 124 by lite on work in its place?
Yes. DVD drives are intercompatable for the most part.these days. just pull out the old one, install the new one, and the OS will install the drivers and it will work just fine.
7/11/2019 7:19:29 PM • Lite On... • Answered on Jul 11, 2019
5answers
Can I Install GDMSS Lite on Windows 10 Laptop?
In case you have a good PC, you can easily install it using Bluestacks. Here are the steps:
  1. Download Bluestacks
  2. Search for "GDMSS Lite"
  3. Proceed with installation.
Source: Download gDMSS Lite for PC on Windows 7 8 or 10 10Downloads com
10/2/2018 4:34:20 PM • Lite On... • Answered on Oct 02, 2018
0answers
No sound comeing out next to volume control yellow lite on says overloaded
Rule number 1 in pc troubleshooting and electronic troubleshooting is to always power down the device and turn it back on to see if that doesn't help, if the problem persists. . . you can call us on your fixya app and we can help you fix your issue with no problem. Hope this helps ?? If you need further help, I’m available over the phone at https://www.6ya.com/expert/brant_4c68df22dda524c2
9/21/2017 12:22:55 AM • Lite On... • Answered on Sep 21, 2017
HI I HAVE SEVERAL
Most power supplies have a fuse in them. That is most likely the problem. Otherwise, if you open them up, you can see which capacitor has gone bad, 'cause they will have obviously ruptured.
4/12/2016 11:46:17 PM • Lite On... • Answered on Apr 12, 2016
3answers
Can't import video into Windows Movie Maker
Windows Movie Maker is a basic video editing and creating software developed by Microsoft. It contains features such as effects, transitions, titles/credits, audio track, timeline narration, and Auto Movie. The accepted formats for import by Windows Movie Maker are WMV, .AVI, MPG, .ASF, .WMA, .WAV, and MP3.
Puzzled about how to import DVD to Windows Movie Maker for further editing? iOrgSoft DVD Ripper can do that job. Not only rip DVD to Windows Movie Maker acceptable videos including AVI, WMV, MPEG-1, MPEG-2, ASF, but also convert DVD to MPEG-4, MOV, AVC (H.264), MOV, 3GP, FLV, SWF.
Tutorial: How to Rip DVD to Windows Movie Maker, import DVD to Windows Movie Maker?
Step1: Locate your favorite DVD to the program-DVD to Windows Movie Maker.
Step 2: Specify output video format compatible for Windows Movie Maker, like AVI.
Step 3: Click “start” button to start the process of ripping DVD movies to .AVI video.
[img]http://www.mp4kits.com/Guides/WMM/dvd-to-windows-movie-maker/importdvdtowmm/convertdvdtoavi.jpg[/img]
12/11/2015 11:14:08 AM • Lite On... • Answered on Dec 11, 2015
2answers
Where i can buy lvw5005
You may have better luck buying one online. Maybe Ebay, the LVW 5005 is discontinued so you will probably not find it in any store
12/4/2015 12:05:59 PM • Lite On... • Answered on Dec 04, 2015
0answers
2answers
Dvd burner wont eject
Open out a paper clip and insert it in the little eject hole on plastic tray cover and push gently until it ejects.
12/15/2014 10:08:59 PM • Lite On... • Answered on Dec 15, 2014
Lite On SHD-16P1S Internal DVD Drive Logo
7 questions posted
Top Lite On Computers & Internet Experts
Steve Pack
Steve Pack
Larry Ng
Larry Ng
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Computers & Internet
Most Popular Question
dvd player used work now doesnt even
  • Computers & Internet
