20 Most Recent
Mag Innovision InnoVision XJ 796 Monitor Questions & Answers
My monitor was fine for
check the cable connected to the monitor
run another monitor on your pc and if it does the same , try installing a serarate graphics board and if you are already doing that, replace that graphic board
No sound on computer- MAG Innovision Model 468
Solution 1 It might have defaulted your sound button to mute Got to control panel Sound and see if sound has been muted
Solution 2 unplug jack out of plug at rear of computer test it in other jack holes what might have happened is that the default setting for speaker and mic might have swapped round best way is play some music and move jack plug around see if you get any sound
Solution 3 Sometimes the sound software needs re setting bring it up and re sett speekers and mike setting by the colours you have you jack in remember front and rear you will be mainly dealing with rear jack interface green pink blue white etc
hope this helps
After resting problem getting screen back
It is possible that you have connected two cables from Monitor to CPU,We need to check if there's a cable that has blue connector (VGA) and another that is HDMI(may be black in color) or DVI (white connector).In case there are two cables that go from the monitor to the computer tower I would suggest you to removing one of the cables will resolve the issue.Feel free to revert for any further assistance
Blurry flat screen monitor
yes you can use those button to adjust the brightness. just press one of the button then it will appear the set up and adjustment.
Mag innovision monitor keeps turning off
It's not communicating with PC video card. It should pick up the input port, but make sure on monitor is set to correct input like VGA. You can try re-seating video card. Also test with VGA if you are using HD like HDMI.
