20 Most Recent Hauppauge Impact VCB Video Capture Questions & Answers
2answers
Hauppage VCB 558 drivers needed
try windows update....Windows might have its own hardware device driver for this...run windows update
9/16/2009 9:13:54 AM • Hauppauge Impact... • Answered on Sep 16, 2009
2answers
No sound in Hauppauge WinTV radio under Windows 7 64 bit
Driver issue? I would go to the manufacturers website to check for compatible software...
7/23/2022 7:12:50 AM • Hauppauge... • Answered on Jul 23, 2022
WHAT IS THE POLARITY FOR HAUPPAUGE win tv-hvr-1950
Here is the support page for your product: http://www.hauppauge.com/pages/support/support.html When you ask about "polarity" are you concerned about the power supply? Also, you might want to look at this Fixya thread: http://www.fixya.com/support/t25141694-wintv_hvr_1950_hauppage_box_suddenly
1/2/2019 8:33:55 PM • Hauppauge... • Answered on Jan 02, 2019
0answers
0answers
0answers
Keeps beeping
Be the first to answer 1/14/2014 4:15:40 AM • Hauppauge... • Posted on Jan 14, 2014Be the first to answer
Retrieve deleted video files
How about some more info. Is it a Hard Drive,SSD, did you use the delete function on the device or an add on app(program) for deletion.
10/31/2013 2:29:49 AM • Hauppauge... • Answered on Oct 31, 2013
0answers
0answers
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?
It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.
The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DYI or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered 5 hours ago
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered 7 hours ago
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered 8 hours ago
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered 12 hours ago
Hauppauge Impact VCB Video Capture Logo
2 questions posted
Top Hauppauge Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hauppauge Televison & Video
Most Popular Question
hauppage vcb 558 drivers needed
  • Televison & Video
