20 Most Recent
Mitsubishi WD-52528 52" Television Questions & Answers
My volume is very low and I can only hear from one
If your TV has a headphone jack, plug some headphones into it and see if the volume works there. If so, make sure the speakers are correctly connected to the TV and that both the wires and speakers are good. (Try other speakers).
I cant have audio when a use the dvi conection :/
Its a early set of this series, If set works from RCA style what are you trying the DVI for? A bit of an explanation of what you hope to gain and what the set is doing or NOT doing would help to assist you.
I have a WD-52528. I
If you followed the procedure to reset the lamp and this is still happening then most likely your lamp ballast is what the issue was. When lamps age and fail, if left too long the ballast unit is prone to fail at some point especially when it becomes open circuit or explodes.
Just like all high powered lamps they reguire a ballast to operate and if yours is bad it will need replacing as well. While your in there look for any bad capacitors in your power supply, look for burned or mushroomed or split capacitors, these can lead to failof the power supply components.
The picture quality on our
Your satellit receiver should have the capability to hook to your TV either by using HDMI cable out from sat unit to HDMI in on TV. This sgould give you sound and audio, or it should have component output which is a series of three cables red, blue and green.The component cablesdon't provide audio so you have to use digital optical or composite cables for sound. Whos satellite box are you using?You should be able to press your menu and get into "system set up" and, there should be an option for HDTV. Go for the highest resoulution(1080 And a ratio of 16 x 9. You tv manual should tell you about screen set up. Let me know
Dave
After replacing lamp tv screen or sound will not
i
have been a tech for 26 yrs now i have seen so many postings on here
about bulging caps and so on but there is only 1 thing to do our
workshop has 18000 dollars in test equipment alone there is a great
reason for this the amount of vereables that can go wrong with nano
electronics there is no easy fix to this problem it needs to be seen by a
certified electronics tech this is your best chance of having this tv
fixed correctly im not putting down other techs on this site but some
things we can fix by computer network some we cant imagine even if this
tv was in my workshop right now it would take us over an hour just to
find and fix the cause
i hope this helps you sir/mam
sonic boom electronics australia pty ltd.
managing director
I dont really have a problem. I just dont know
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Timer light keeps blinking
you probably had a power bump, unplug tv for 1 hour turn back on and hit the reset button, if the green light quits blinking your good to go. If not you might have capacitors gone bad not cool.
For my Mitsubishi WD-52528..is there
If you have no indications of power, i.e.; no LED's on the front light up at all, then there may be a problem in the power supply of the set. I doubt that it is as simple as a fuse that needs replaced. If there is a fuse that has opened, then you may still need a technician to replace it, as most of these sets have what are called Pico fuses in them.
If there are any LED's that light up at all, then I would suspect the lamp. You have not indicated that you have replaced the lamp, but that is the first thing that I would replace. If you have replaced the lamp and you have some indication of power then there are other components that need to be checked. The ballast for the lamp, the cooling fans are among the items that could keep your set from powering up.
Please respond to this post with more information as to whether or not you have any LED's that light up or if you have replaced the lamp lately.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
TV will not come on. I pull out the power plug
Your power supply aka high-voltage transformer is shot. Very Very common in mitsubishi tv's. They seem to have the most problems.
You can possibly order one from tigerdirect.com or partstore.com or shopjimmy.com
It will have to be difused with a difuser to draw out any remaining power left in the supply/transformer, then it will have to be soldered off and the new soldered on.
It is common because parts are made cheaper and quicker now days. Have had to replace many of these lately.
I have a 52
Ur LCD inverter board it dead,need it replaced,U have light go to LCD Screen right?
