20 Most Recent Sony Ericsson Unlock By Code S312 W100a W100i W150 W150a W150i Questions & Answers
my mobile sonyericission w150i hard rest codes plz tell me
Sony Ericsson... | Answered on Apr 21, 2018
sony ericsson w150i reset code
Sony Ericsson... | Answered on Aug 10, 2014
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Sony Ericsson... | Answered on Aug 12, 2012
The charging base is loose you have to replace.
It will work.
Sony Ericsson... | Answered on Oct 09, 2017
What is the question?
Computers &... | Answered on Aug 12, 2017
go here for manual
http://www-support-downloads.sonymobile.com/st15/userguide_AE_ST15_1252-0138.1.pdf
Sony Ericsson... | Answered on Jun 04, 2014
Does it work with just the battery or just the power supply? May need a new battery as they do not last forever. It may also need a new powers supply. Test if it works for one but not the other as that is the key.
Sony Ericsson... | Answered on Apr 24, 2014
Probably shorted the power supply, but may have only blown the fuse. If you have a manual find where that fuse is and replace it. If it is not the fuse, replace the power supply, and cord as it is not expensive and is worth a try. Unfortunately, you may have fried the mother board. Amazon sells one for less than 50 dollars and it is easy to replace if you follow the instructions. There is a chance you may fried the CPU which could be more expensive. The hard drive is not, but may have been damaged too. It's worth a try on all counts as Sony's are not cheap to reacquire and that accident is not covered by your warranty as something that happens under normal use.
check access point setting manually
get access point setting of your operator
Sony Ericsson... | Answered on Apr 11, 2014
Hahahahah You've been BLOCKED by You Tube? (Or your parents?)
Sony Ericsson... | Answered on Jan 25, 2014
Sony Ericsson Unlock By Code S312 W100a W100i W150 W150a W150i Logo
20 questions posted
Top Sony Ericsson Computers & Internet Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Computers & Internet
Most Popular Question
master reset code sony ericsson w150i
  • Computers & Internet
