20 Most Recent Sony Ericsson Xperia Neo V - MT11a - Blue Questions & Answers
Do you mean the network unlcok?You can approach Classicunlocking.com and get the required unlock code for your Sony Xperia Neo V.You need to specify the country,locked network and based on the availability get the unlock code along with free unlcok instructions.
Sony Ericsson... | Answered on Apr 03, 2019
The charging base is loose you have to replace.
It will work.
Sony Ericsson... | Answered on Oct 09, 2017
What is the question?
Computers &... | Answered on Aug 12, 2017
go here for manual
http://www-support-downloads.sonymobile.com/st15/userguide_AE_ST15_1252-0138.1.pdf
Sony Ericsson... | Answered on Jun 04, 2014
Does it work with just the battery or just the power supply? May need a new battery as they do not last forever. It may also need a new powers supply. Test if it works for one but not the other as that is the key.
Sony Ericsson... | Answered on Apr 24, 2014
Probably shorted the power supply, but may have only blown the fuse. If you have a manual find where that fuse is and replace it. If it is not the fuse, replace the power supply, and cord as it is not expensive and is worth a try. Unfortunately, you may have fried the mother board. Amazon sells one for less than 50 dollars and it is easy to replace if you follow the instructions. There is a chance you may fried the CPU which could be more expensive. The hard drive is not, but may have been damaged too. It's worth a try on all counts as Sony's are not cheap to reacquire and that accident is not covered by your warranty as something that happens under normal use.
check access point setting manually
get access point setting of your operator
Sony Ericsson... | Answered on Apr 11, 2014
Hahahahah You've been BLOCKED by You Tube? (Or your parents?)
Sony Ericsson... | Answered on Jan 25, 2014
Check whether your sim is placed properly in the slot. Try to reinsert the Sim. Still if you face the same problem then your phone might be locked to particular Network. To solve this problem you need to get your phone unlocked. You can unlock your Sony Ericsson phone using unlock code. You can get the unlock code for your phone from your Network service provider or Network service provider or any third party online vendors like Unlock-Zone.com here you need to specify your country, current Network name, IMEI number of your phone. Then they deliver unlock code to you through mail with unlocking instructions. Using this you can unlock your phone from Network lock easily.
Sony Ericsson... | Answered on Dec 28, 2013
I DO NOW
Sony Ericsson... | Answered on Nov 30, 2013
Are you referring to network passcode? If so you can purchase such code from any vendors online like Onlinegsmunlock.com
Sony Ericsson... | Answered on Nov 01, 2013
Sony Ericsson Xperia Neo V - MT11a - Blue Logo
2 questions posted
Top Sony Ericsson Computers & Internet Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Computers & Internet
Most Popular Question
unlock sony xperia neo v mt11a
  • Computers & Internet
