20 Most Recent
Equator EZ 2512 CEE Front Load Washer / Dryer Questions & Answers
My equator EZ 2512 CEE washer/dryer suddenly wont
If you are still looking for a solution to this here it is:
In these machines if you try to change the setting of the washer knob without letting a cycle finish which is already set it may happen that the unit won't function properly and hence the unit needs to be reseted. There is a reset procedure for the same and let me know if you would like have the same.
If the door is not opening it is advisable to reset the unit first and then try opening the door which should work and also the door handle won't break then.
If you have already replaced the door handle on your machine it is fine or else you may want to order the same from appliancedesk.com
Equator door handle
Here is the phone number for equator, 1800-935-1955 or parts and service 800-776-3538. They sould be able to help you.
Their address is 10067 Timber Oak Dr. Houston, TX 77080-7045
Fan belt broken?
The motor bracket is broke, which allows the motor to "jump" causing the belt to come off.
Dryer not drying properly
Check you drain hose is if it is kinked or obstructed an anyway, there is a filter element on the end of the pump it may be cloggedthe pump is self cleaning. the pump is located on the bottom. the condenser is on top center and the blower motor is in the center. also check the impeller at the end of the condenser motor..let me know if this helps
How do I reset my Equator Super Combo washer Dryer EZ4000?
To reset your Equator Super Combo washer dryer EZ4000, you can try the following steps:
1. Unplug the unit from the power source and wait for a few minutes.
2. Plug the unit back in.
3. Press and hold the "Start/Pause" button for about 5 seconds to reset the machine.
This should reset the washer dryer and clear any error codes that may be causing the issue.
Regarding the door interlock switch, you can try finding a replacement locally by contacting appliance repair shops or stores that specialize in appliance parts. You can also search online for retailers or websites that sell spare parts for Equator appliances. Provide them with the make and model of your washer dryer to ensure you get the correct part.
If the above steps do not resolve the issue with your washer dryer, it may be best to contact Equator Appliances directly or consult a professional appliance repair technician for further assistance. They will be able to provide you with more specific guidance and help you troubleshoot the problem effectively.
