20 Most Recent
Directed Extreme XA-5001 150W x 1 Car Amp Car Audio Amplifier Questions & Answers
The fuse in the red wire that connects to the battery blows
Hello super11dt,
Sounds like the power and ground wire are shorting. Check the power wire with a multimeter. Sometimes, the insulation gets rubbed off and it contacts the vehicle metal causing a short. The solution is to pull a new wire and install a grommet or bushing wherever it goes through the firewall.
Actually, the negative (ground) wire should not be run to the battery at all. It should be secured to the metal of the vehicle as close to the amp as you can get, preferably within about 3 feet.
Hope this helps.
The amplifier keeps on blowing out the fuse when i
Start by dis-connecting the power lead at the amp, and securing it (where the bare wires are not touching ground) Now insert a new fuse then make the battery connection. If the fuse blows then you need to trace the power wire to find the short, or replace the entire wire, paying close attention to sharp edges and pinch-points that could cause this problem to reoccur.
If the fuse didn't blow, dis-connect the power lead at the battery then all of the other connections at the amp, reinstalling the power lead to the amp. With only the power lead connected at the amp and the good fuse inserted, reconnect at battery,and if the fuse blew then the problem is with the amp. and should be repaired or replaced depending on its value and the cost effectiveness of those two options.
If the problem has not yet been discovered, continue with tracing each of the remaining amp wires in that manner, as been described above.
Good luck...
I purchased a used car
Good day kvanhook!!!
That cables should be connected properly in each corresponding colors (colors by colors).
Then tell me what will happen...If that cable connection did not work just add a comment..
Thank you!!
The cords that connect into the bottom of the DVD
If you would like to have a temporary fix, I would disconnect the cables from the headrest unit, use electrical tape to cover the bare wires, and then go to Radio Shack or another hobby shop and get shrink tubing. Do not cut the shrink tubing along the length of the tube, only cut it to the size of the area that you need to cover. Then you can use a hairdryer on the highest heat to shrink the tubing down in order to cover the exposed wires.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
