20 Most Recent
Western Digital Caviar SE16 (WD5000KS) (5000KS20PK) 500 GB Hard Drive Questions & Answers
Hi my logic board is
If there is a bios chip on the board, heat it to remove it and change it with the bios chip on the new board.
My computer is not recognizing
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical
extensions,IDE,SATA
the leads from your
"((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or
just replace them they could be faulty
make
sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have
secure connections and are not faulty even the electical extensions or just
replace them they could be faulty a computer needs its connections to continue
its cycle and have an end so any faulty leads will end up with a computer error
hope
this helps
Where could I find a
Check in your BIOS,first make sure the SATA controller is set to native mode and not RAID, and secondly that the BIOS can detect the drive, if the drive can't be detected by the BIOS then it's because the drive surpasses the boards drive size limitation.; If this is the case there is a chance a BIOS update may fix it but it's not guaranteed it will.
Bios reads the fact that
once in system BIOS try f1 for general help or booting in optimised defaults or failsafe defaualts
The bios does not see the Western Digital Caviar
Hi, on the rear of the drive there are a series of pins with a small plug coveing two; you need to remove the pin and alter the placement for either, master or slave depending on what you are using the drive for; you will see a small diagram telling you where to place the plug. Hope this helps
I have a WD CAVIAR
It would be very difficult to locate the spare parts for your hard-drive since it is manufactured 6 years back and is already out of warranty period. Even if one does manage to find the spare part, it is not sure that the drive will work. So,it would be better if you go for a data recovery procedure if you have valuable data on the disk.
Hope this helps. For more help and clarifications,please reply. Thanks.
Maxtor basics hard drive and my xbox 360
Does your drive make any sounds similar to
these?
If yes you have a mechanical problem and you should get a specialist to work on it if you need that data.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
MAXTOR 1TB not recognised by XBOX 360
see if there any updates for the xbox 360 in terms of flashing the bios or something along those lines - not sure if you can get into the configuration to alter any settings regarding or relating to detection of hard drives.
Wd500aaks driver
All you have to do insert any operating system bootable disk and then boot in CD/DVD rom and partition HDD and format and then install the operaitng system.
Here a guide on installing windows xp operating sytem :
http://www.geekgirls.com/windowsxp_install.htm
hope this help
Western digital 500 gig hd eide disc error????
Take it back to the store - this is a common problem with WD drives and WD are doing nothing to address this issue with their larger drives. Buy another make and you should be trouble free.
WD Caviar SE 16
Have you installed it as the main drive, ie the one with the ops system on, or have you installed it as a secondary drive? Either way, check you have the drive set up correctly as per instructions on pack. You are not alone with this problem either, it is common with WD. Come back to me with more info re your install.
Personally, I would set it up in an external enclosure and access via USB. Much more realable that way, and it is portable for you.
Western Digital 500GB SATA
Hi, you dont say whether you have it installed in the pc, or is it in an external usb enclosure? Come back to me and I will try for you.
WESTERN DIGITAL CAVIAR SE 500 GB
Hi, looks like your usb drive has died. Try it on another pc / laptop first. If it still does not work, you will need to purchase drive data reader while will allow you to access the data. Most pc stores carry them. Cost about 50 euros. Best of luck.
Installation
The hard drive will automatically install you do not need to install a driver. I'm guessing this is a hard drive in addition to the hard drive that vista is running on? If so you probably need to format the hard drive to gain access to it. Click the windows button, and in the search field type compmgmt.msc and hit enter. Click continue when the UAC pops up. Now inside the Computer Management Console find and click on Storage and then Disk Management. On the bottom portion look for your new hard drive. Most likely it will have a black colored stripe and say UNALLOCATED.
This will explain how to do the rest Yes that article is for XP but the one in Vista is pretty much the same.
