20 Most Recent
JBL GTO937 Car Speaker Questions & Answers
Hi,need to install 6x9 spreakers to my bmw e36
You can make some plates from mdf or the like to "lift" the 6x9's up (can also be bought, but I can't remember were I bought mine from, was a while ago). just cut some mdf to take the speaker and cut about 1" around, paint or cover with material and screw through to the shelf.
Selecting an amplifier!
Buy a quality 2 channel amp. About 600 rms and set one channel as your highs using your crossover and then the second channel on "low" position for your sub. wire directly in to your low's channel with your sub at 2 ohms and then wire your speakers to the other channel.
Hi bought jbl gto 937 speakers,next week going to
Hello a_vital84,
You can safely use 8 gauge power and ground up to about 400-500 watts RMS. Actually, for the current your amp will draw, even at maximum power, a 10 gauge would suffice. But the difference in price is so minimal that it makes no sense to buy a 10 gauge wiring kit. Who knows, you may decide that the amp doesn't provide enough power and want to go to a bigger one, in which case you'll already have the proper size wire pulled. Just select a brand name kit that includes ring terminals, fuse, and RCA input cables. The most economical are Metra and Scosche. Streetwires (by MTX) and Monster Cable are more expensive. And some branded Rockford-Fosgate or Kicker will cost you the most. But they will be the very best kits with oxygen free copper and all of the needed installation hardware. You can see a variety of amp wiring kits at
www.crutchfield.com or
www.sonicelectronix.com. Either online store is a good place to buy from also. The Crutchfield site also has loads of good information that is well worth your browsing time.
Hope this helps.
Hi,just bought a 6x9 jbl gto937 speakers for my
Pyramid makes the PB series of amps. I have one that's driving a Sub.
The PB 700 puts out rms 60watts x 2 @ 2ohms, which gives you some "headroom" for your speakers. You don't want to over drive speakers with , for example, a 1000 watts for 100 watt speakers, because that's a good way to blow your speakers.
There are many brands and models of amps that will fit your speakers. Just make sure the amp will drive 2ohm speakers, since your jbl's are rated at 2ohm impedance.
You may want to consider adding a Sub woofer to your setup. A single Sub would fill in the low end very nicely. If you got a 4 channel amp, then two channels will drive your jbl's, and you can bridge the other two channels to drive the Sub. That would be a kick'n sound!
Just make sure the amp is bridgeable
For example, the Pyramid PB 1200 is a 4 channel, bridgeable amp. This particular amp will drive the 2ohm jbl's, but you would want a 4 or 8 ohm Sub connected to the bridged channels.
