20 Most Recent Estate TAWS800JQ Top Load Washer Questions & Answers
2answers
My Estate TAWS800JQ washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin. If knob is manually moved from drain cycle to rinse unit will agitate but not drain or
Possible that the drain pipe is in a height where the water is struggling to lift. If not id check for a block. I normally find a sock stuck in the drain hose which causes a problem similar to yours
9/24/2017 7:33:03 PM • Estate TAWS800JQ... • Answered on Sep 24, 2017
Whirlpool Estate (model # TAWS800JQ) My
Most likely the lid switch has failed
9/13/2017 8:18:22 PM • Estate TAWS800JQ... • Answered on Sep 13, 2017
How do i stop my washer from smelling
try adding fabric softener or pour a cup of ammonia in it when the wash is completed .
10/12/2016 3:38:22 AM • Estate TAWS800JQ... • Answered on Oct 12, 2016
Why do clothes wash but come out with lint on them?
some machines have a lint trap or filter and some do not , and the most common mistake is adding too much detergent that leaves like a lint.
10/12/2016 3:34:09 AM • Estate TAWS800JQ... • Answered on Oct 12, 2016
I have an Estate TAWX700JQ3
That is meaningless. The important rule is to be sure the clothing you load in can float freely in the amount of water you give it, always use powdered detergent and the warmest water the colors involved will tolerate. Don't wash things that float, don't jam your comforters in your home machine....
7/26/2016 3:40:20 PM • Estate TAWS800JQ... • Answered on Jul 26, 2016
Agitator does not move
No wash agitation or spin? try these: WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open. Another test u can make with a multi meter is by testing the prongs individually. # 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch. (where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open. . Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly. Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it. Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Transmission or clutch assembly not engaging due to going out or slipping. Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly. CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub) Remember to check the agitator spline as well for worn broken teeth. By the way my advice is free cuz God is good!
4/25/2016 9:28:33 PM • Estate TAWS800JQ... • Answered on Apr 25, 2016
Machine stops while water is filling up
DO U MEAN IT DOES NOT GO INTO WASH CYCLE? No wash agitation or spin? try these: WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open. Another test u can make with a multi meter is by testing the prongs individually. # 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch. (where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open. . Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly. Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it. Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Transmission or clutch assembly not engaging due to going out or slipping. Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly. CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub) Remember to check the agitator spline as well for worn broken teeth. By the way my advice is free cuz God is good! 23503892-5l44rnzs0d0ajyywclqoqvey-2-0.jpg 23503892-5l44rnzs0d0ajyywclqoqvey-2-2.jpg 23503892-5l44rnzs0d0ajyywclqoqvey-2-5.jpg 23503892-5l44rnzs0d0ajyywclqoqvey-2-9.jpg 23503892-5l44rnzs0d0ajyywclqoqvey-2-14.jpg
4/25/2016 9:25:56 PM • Estate TAWS800JQ... • Answered on Apr 25, 2016
Inlet hose placement
THE INLET VALVE HAS MARKINGS FOR COLD AND HOT HOSES? NOT SURE WHAT YOU MEAN? 23700571-5l44rnzs0d0ajyywclqoqvey-2-0.jpg 23700571-5l44rnzs0d0ajyywclqoqvey-2-2.gif 23700571-5l44rnzs0d0ajyywclqoqvey-2-5.jpg 23700571-5l44rnzs0d0ajyywclqoqvey-2-9.jpg
4/25/2016 7:18:04 PM • Estate TAWS800JQ... • Answered on Apr 25, 2016
Take aggetator out of whirlpool washing machine
SEE PICS 23769804-5l44rnzs0d0ajyywclqoqvey-2-0.jpg 23769804-5l44rnzs0d0ajyywclqoqvey-2-2.jpg 23769804-5l44rnzs0d0ajyywclqoqvey-2-5.jpg 23769804-5l44rnzs0d0ajyywclqoqvey-2-9.jpg 23769804-5l44rnzs0d0ajyywclqoqvey-2-14.jpg 23769804-5l44rnzs0d0ajyywclqoqvey-2-20.jpg 23769804-5l44rnzs0d0ajyywclqoqvey-2-27.jpg 23769804-5l44rnzs0d0ajyywclqoqvey-2-35.jpg 23769804-5l44rnzs0d0ajyywclqoqvey-2-44.png
4/25/2016 7:15:09 PM • Estate TAWS800JQ... • Answered on Apr 25, 2016
How to check switch on estate washing machine?
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller. Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically. Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand. Or try the hand test: If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day. - put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand - turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin - if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand - if it takes very little force to stop the tub from spinning, the clutch needs to be replaced. Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either) Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle. On some front load models u may need to check the STATOR assembly. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage. LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN By the way my advice is free cuz God is good! Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore... 24248713-5l44rnzs0d0ajyywclqoqvey-2-0.jpg 24248713-5l44rnzs0d0ajyywclqoqvey-2-2.jpg 24248713-5l44rnzs0d0ajyywclqoqvey-2-5.jpg 24248713-5l44rnzs0d0ajyywclqoqvey-2-9.jpg 24248713-5l44rnzs0d0ajyywclqoqvey-2-14.jpg 24248713-5l44rnzs0d0ajyywclqoqvey-2-20.jpg 24248713-5l44rnzs0d0ajyywclqoqvey-2-27.jpg
4/25/2016 7:02:01 PM • Estate TAWS800JQ... • Answered on Apr 25, 2016
Washer smells moldy
get washer refresh
4/1/2015 12:16:19 AM • Estate TAWS800JQ... • Answered on Apr 01, 2015
2answers
How do I replace drain hose
Do you mean the hose that goes to your standpipe, or the hose that goes from the drain pump to the plastic box(26) behind the washer? In any case, to remove the hose (8) going from the back of your washer to the stand pipe, grab a pair of pliers and squeeze the wire fingers sticking out of the clamp (28) holding the drain hose to the plastic box on the rear of your washer. That relieves the tension of the clamp and, while still squeezing the wire fingers, slide the clamp up the drain hose a couple of inches. Then, you can pull the drain hose loose from the plastic piece. Then, using your pliers again, completely remove the clamp from the old drain hose and put it on your new drain hose, about 3 inches back. Then, stick your new drain hose onto the plastic piece and use your pliers to get the clamp back down to secure the drain hose to the plastic piece. You should be able to figure it all out with no problem. 25253094-y0ype1io4qnva3mnnhfzjpig-1-0.jpg
1/28/2015 2:00:06 AM • Estate TAWS800JQ... • Answered on Jan 28, 2015
My estate washer is leahking in the front
Check the door seal for tears
1/16/2015 12:31:52 AM • Estate TAWS800JQ... • Answered on Jan 16, 2015
Clothes wash but come out with lint on them
Further to my answer yesterday: If you have a manual filter remove and clean. Tub drain may be blocked. Self cleaning filter or trap may be clogged. Regards, Dennis
8/18/2014 11:11:12 AM • Estate TAWS800JQ... • Answered on Aug 18, 2014
Why do clotheswash but then come out with lit on them?
There are certain fabrics that shed lint...towels and sweaters for example...do not wash those with shirts and socks and other items that do not. Separate your loads and you should not have the problem. Regards, Dennis
8/18/2014 1:54:57 AM • Estate TAWS800JQ... • Answered on Aug 18, 2014
When the wash cycle is done very small amount of water drips into the tub.
The circuit board could be at fault
3/26/2013 3:02:17 AM • Estate TAWS800JQ... • Answered on Mar 26, 2013
Need to get the discharge hose off from
Use a pair of pliers to remove the hose clamp upwards. Pull the hose off. Here is the new hose to order.
11/12/2012 3:49:42 AM • Estate TAWS800JQ... • Answered on Nov 12, 2012
Water filter clogged
Remove and clean the filter. Please check for tips from this linkClick on: Filter
6/27/2012 10:50:40 AM • Estate TAWS800JQ... • Answered on Jun 27, 2012
Estate TAWS800JQ Top Load Washer Logo
142 questions posted
Top Estate Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Estate Washing Machines
Most Popular Question
washer filled water quite doing
  • Washing Machines
