20 Most Recent
Kicker ZX400.1 Car Audio Amplifier Questions & Answers
Have a kicker zx400.1 hooked
Set the gain to %50 and see what happens, also make sure the amp is well ventilated and not upside down. It has thermal switches for overheating.
Zx400.1 protechion light blinks
Your amp is going into protection mode, it might be either overheating, when the bass drops or there may be a wrong connection somewhere in the amp.
Good luck..
Lex
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
I have a zx500.1 amp
If the amp is in protection mode, there is either wires touching somewhere or a short. Otherwise the amp itself has an internal problem and would need repair or replacement. If you have any other questions please let me know.
Thank you,
Lee
