20 Most Recent
Estate TGDS740JQ Gas Dryer Questions & Answers
No heat
Sounds like a blown fuse, check your fusebox and replace all going to your dryer. May correct the Problem:)
Dryer tumbles, but does not heat
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this
gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis
electric no heat tip...heatman101
Dryer does not heat. We did clean vent hose and
gas no heat tip....
check outthis
heatman101=-\=-\
Dryer not heating up
gas no heat tip....
check out this
heatman101
When turning on the dryer it blows but it is not
gas no heat tip....
check out this
heatman101
Dryer is not heating enough to dry clothing
gas no heat tip....
check out this
heatman101
87gh
Gas dryer does not ignite
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
if you dryer is gas check out this gas no heat tip....
check out this electric no heat tip...
heatman101
Estate TGDS740PQ0 gas dryer not heating
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
When drying clothes in my gas dryer, you can smell
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Drum not turning
pull the loop down at the bootm of the drum feed that loop through and under the pully wheel then catch the loop on the motor pully you can lift the idler pully slightly to get more slack
