20 Most Recent Kaz Honeywell Tower Air Purifier with IFD (HFD-120) Air Purifier Questions & Answers
The solution is simple. Just press on the little red light that says to reset filter. Its a button that will reset the warning and the light should go out
Kaz Honeywell... | Answered on Dec 28, 2011
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
Kaz Honeywell... | Answered on Nov 07, 2010
their may be a reset button on the cord where it plugs into the outlet .check this ..let me know ..good luck/joe
Kaz Honeywell... | Answered on Aug 30, 2010
Check to see if there is power getting to your device. If it is a 110-volt unit, plug a lamp or other device into the same outlet the device is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet. If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas: Wiring (Inspect for any broken or burnt wiring) Selector switch Control board Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
Take care.
Kaz Air... | Answered on Oct 10, 2010
Google IT JUST AS WE COULD
Air Purifiers | Answered on Apr 11, 2019
Air Purifiers Logo
20 questions posted
Top Kaz Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Kaz Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
Kaz Air Purifiers
  • Kaz Air Purifiers
Most Popular Question
kaz honeywell tower air filter rest
  • Air Purifiers
