20 Most Recent Venta VS 100 Humidifier Questions & Answers
2answers
Ventasonic humidifier blows air but no mist.
Change to ceramic oscillator, problem is... they don't sell them.
8/28/2019 6:25:25 AM • Venta VS 100... • Answered on Aug 28, 2019
4answers
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
6/26/2011 6:44:00 PM • Venta VS 100... • Answered on Jun 26, 2011
White dust
Change the filter, use RO or distilled water. Your tap water is too hard.
4/14/2011 12:20:02 AM • Venta VS 100... • Answered on Apr 14, 2011
The Venta Sonic stops working,,,,it just keeps
here is the manual that may lead you to the solution..
http://www.appliancefactoryparts.com/content/pdfs/123737.pdf
2/19/2011 4:46:11 PM • Venta VS 100... • Answered on Feb 19, 2011
Cleaned it. Now it won't work
Might be low water/tip over switch not reset.check water container for proper allighnment.
3/12/2010 9:54:12 PM • Venta VS 100... • Answered on Mar 12, 2010
Need the part that hooks the new filter to the humidifier
It is the cap. try www.ventahumidifiers.com
8/23/2009 4:02:34 AM • Venta VS 100... • Answered on Aug 23, 2009
Unit only works upside down!
there is a water level next to the ocilater make sure that the canal is clean. try some water and vinegar
7/3/2009 2:48:56 AM • Venta VS 100... • Answered on Jul 03, 2009
Vesta VS10 ultrasonic humidifaer turns on, fan runs but doesn't p
change the filter
2/27/2009 5:08:01 PM • Venta VS 100... • Answered on Feb 27, 2009
Can't find the manual online VS207
I have tried looking for a manual for you but I could not find anything after a long search, however here are the contact details for venta, they should be able to send you a manual/guide
Main support number1-888-333-8218
Email support[email protected] I hope this helps
1/7/2009 4:41:01 PM • Venta VS 100... • Answered on Jan 07, 2009
I purchased a Sunpentown digital
Sunpentown has an 800 customer service number: 800-330-0388 in California. Maybe they can email or snail mail you a copy.
1/6/2009 12:04:40 AM • Venta VS 100... • Answered on Jan 06, 2009
0answers
Hi my venta humidfier does not make any steam, i brought a new VASHER please let me know how to fixed.
venta-usa.com is your best bet to solving the problem.
2/7/2018 8:49:38 PM • Venta... • Answered on Feb 07, 2018
0answers
Venta VS 100 Humidifier Logo
19 questions posted
Top Venta Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Venta Humidifier Expert? Answer questions, earn points and help others
View Most Popular
Venta Humidifiers
  • Venta Humidifiers
Most Popular Question
find manual online vs207
  • Humidifiers
