20 Most Recent Nikon Coolpix 8800 Digital Camera Questions & Answers
Just inherited this camera. I can see the image fine on the screen, but can't see anything in the viewfinder when I switch between screen and viewfinder.
viewfinder is ng - live with it since cost of repair is prohibitive.
12/1/2015 3:11:03 PM • Nikon Coolpix... • Answered on Dec 01, 2015
Why is my nikon 8800 stuck at 1/3000 and the display/view finder display a stretched image in pinks, blues and brilliant white?
Could be a result of any of the accidents they warn you about in the manual. Heat, cold, direct sunlight, dropping, water or magnetic feild. does it take a picture?
7/23/2014 2:08:57 PM • Nikon Coolpix... • Answered on Jul 23, 2014
Problem with the Nikon Coolpix 8800 Digital
my Nikon 8800 vr cool pics will not turn on with a new battery but will work on ac
11/13/2013 7:12:02 PM • Nikon Coolpix... • Answered on Nov 13, 2013
Why does my camera say system error 2 after every pitcher i take
Contact Nikon at their website and ask them!
12/28/2012 12:50:53 PM • Nikon Coolpix... • Answered on Dec 28, 2012
How do I turn off the flash for my nikon coolpix 8800
In any of the point&shoot modes the camera will decide whether to fire the flash or not.In the P, S, A, and M modes, press the MENU button. Select "Show all menus" and press the button in the center of the multiselector (I'll call this the OK button from here on). Scroll down to "Speedlight opt" and press OK. Select "Speedlight cntl" and press OK. Select "Internal off" and press OK.Full details are in the "Speedlight Options" section of the manual (page 104 in my copy). If you need a manual, you may download a copy here.
12/14/2012 3:34:44 AM • Nikon Coolpix... • Answered on Dec 14, 2012
2answers
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
10/20/2012 3:23:34 PM • Nikon Coolpix... • Answered on Oct 20, 2012
My computer no recognise mi camera,
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
8/15/2012 8:33:54 PM • Nikon Coolpix... • Answered on Aug 15, 2012
Won't hold charge so need
The Nikon 8800 uses the EN-EL7 battery. One source for the battery is the manufacturer, but they want about USD 66 for one.
9/26/2011 7:24:36 PM • Nikon Coolpix... • Answered on Sep 26, 2011
Message in display says that
There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article fix memory card not formatted error and learn how to fix it step by step. Best regards.
9/8/2011 3:15:24 AM • Nikon Coolpix... • Answered on Sep 08, 2011
When I shot each photo,
System Error 2 on Nikon Coolpix 8800 is usually after blow, even the small one, when you or somebody kick the camera and yes, FULL RESET on Set Up mode is just one solution. It's camera's error not the card.
From Nikon website:
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
We apologize for the inconvenience and will do everything we can to repair your Nikon camera as quickly as possible.
Good luck.
6/3/2011 8:59:47 PM • Nikon Coolpix... • Answered on Jun 03, 2011
Error 2 in my coolpix
hi your camera has system error, usually the lens unit doesn't reset after taking picture. it cause error message. you should contact to nikon service center and ask them repair cost. usually they will tell on the phone. thanks and best regard!
5/23/2011 5:09:31 AM • Nikon Coolpix... • Answered on May 23, 2011
When I put a Compact
Confirm the features of your SD Card with this Nikon information...
** While "WA" (Write Accelerated) cards may be approved for use in this camera, no speed improvements will be noted over non-WA cards.
Additionally, look inside the C.F. card slot. I would bet that you will see a couple of bent pins, one on each end of the connector. If you do find bent pins you can usually straighten them out with a very small screwdriver. Check that the card in the slot is positioned correctly.
Keep us updated.
4/15/2011 11:40:15 AM • Nikon Coolpix... • Answered on Apr 15, 2011
Lens error
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
3/22/2011 7:46:52 PM • Nikon Coolpix... • Answered on Mar 22, 2011
Nikon Coolpix 8800 Digital Camera Logo
91 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
just inherited camera see image fine
  • Cameras
