20 Most Recent
MTX (SLH-T7512X2-A) Car Speaker Questions & Answers
My subwoofer will not work at all!!!
Actually, you could be in luck.
If you are getting 'absolutely nothing', it could be something simple. Open it up (carefully) and make sure the wires are secure on both the speaker and the inner connection leads.
I've come across several this has happened to that were brand new.
Good luck
Mike
7/29/2010 4:04:15 AM •
MTX...
Answered
on Jul 29, 2010
My subwoofer only works when the weather is warm
nice way to ask something :) you must open the subwoofer box and check the connections. the problem is bad contact. with cold all metals shrinks and with warm they expand and make contact.
Don´t forget to rate.
Thanks
6/17/2010 11:59:53 PM •
MTX...
Answered
on Jun 17, 2010
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
4/8/2010 11:17:12 PM •
MTX...
Answered
on Apr 08, 2010
