20 Most Recent
MTX Thunder 5-Channel Amplifier 895 Car Audio Amplifier Questions & Answers
Ayuda con el MTX THUNDER 895
Ojala que no pagastes mucho por el. SI tienes un tecknico cerquitas te lo puede reparad barato. Si lo tienes que mandar a MTX no conveine.
Necesito saver el valor de
He needs schematic info about the values of the resistors, R1013 and R1014
I cant find a schematic for this amp. Anybody have one?
Sorry not a solution but might help.
Trying to find the right FET to replace burnt up ones with
hafler use international rectifier hexfets. there is alot of confusion what constitutes a mosfet amplifier.
if the outputs are mosfets instead of bipolar transistors, it is a mosfet amp.
some designs are using mosfets to drive the switch mode power supply,but use bipolar output transistors.that is not a true mosfet amp.
you need to go to an electronic supplier for the repair industry.
or the manufacturers warranty depot,who will be able to order them.mosfets are very high current devices,you have to ask ...why did they fail. if they are the switch mode drivers,there is bad capacitors in that circuit
