20 Most Recent
Fisher Price Deluxe Perfect Support Baby Carrier Questions & Answers
Don't have manual for fisher price ocean wonders
All pack and play play yards require the bottom floor to lifted like a little volcano in the middle before the side will go up or down. Some have a twist lock others just pull upward. Lift the middle handle up about 6" to 12" and then raise the sides. Once all the sides are up, press the floor flat. Done. Nothing goes up or down until the middle safety is up like a volcano.
Seat Replacement part for F/P Jumperoo
For most replacement items, you can visit https://store.mattel.com/ and purchase them. Unfortunately, for this item only the foot pad and legs are available for purchase.
Directions
This will be hard to explain, but please bear with me. The 1994 unit I have is on ebay right now...I would imagine newer models are similar.
http://cgi.ebay.com/Fisher-Price-Perfect-Support-Baby-Carrier-Gently-Used_W0QQitemZ290040314299QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
The baby seat portion has one color clips, while the adult portion has a different color clips. Mine are white, and turquoise. The baby part has two 'buttons' near the **** area. Depending which one is snapped into the V shape notch on the adult part, the baby either faces toward the adult, or outward.
The adult harness makes an X on your back, with a U shape in the front. The wider band part goes around the adults waist. On the baby seat part,the white clips go around the baby's tummy, similar to putting on a diaper. The turquoise clips on the baby part clip to the turqouise clips on the adults front shoulder area. Each strap is then adjustable for correct length.
Hope this helps. I got mine at a garage sale, too, and it took awhile to figure out.
The little red frog/lizard gets
It's hard to say without seeing it, but often the cause of a sticking component in a mechanical moving part is caused when the part in question becomes misaligned, like a sliding door that gets jammed when it's opened hard or lifted while opening.
One thing that often helps sliding components to move freely is applying a bit of chapstick. I have used Chapstick on slicing windows, drawers, bicycle cables and probably other things. The wax acts as a clean, non-oily lubricant that doesn't smell or stain. Use with discretion since this is a baby toy!
Did this help?
My son was given a
I had this problem until i played around with it. Switch it on as normal, then at the front of train, move the blue switch to the left fully and then press the green chimney bit, and it should start moving.
Baby carriers what do you
nothing, this is not babyco it is many members of the public with some skill in explaining how to repair damaged goods, to people who have damaged goods
My cradle swing isn't playing
there will be no way of fixing this it will have to go back to the manafacture . hopfully its still under warrenty.
Fisher Price Deluxe Perfect Support Carrier
There are many companies that make baby carriers now. Fisher Price may have discontinued it, but I don't see a recall for it. I saw some on E-bay http://search.ebay.ca/fisher-price_Baby-Carriers-Slings_W0QQfclZ3QQsacatZ146535
