20 Most Recent Fisher and Paykel 24 in. DS603H SS Free-standing Dishwasher Questions & Answers
0answers
0answers
0answers
Section6.1
Be the first to answer 8/17/2013 10:03:10 PM • Fisher and... • Posted on Aug 17, 2013Be the first to answer
Fisher paykel dishdrawer
It is likely the top panel of the drawer needs cleaning.First turn off the mains power to dishwasher and take the plug out if accessible. Wait a little and put the plug back and turn on the mains power. If this does not fix the problem, then get clean damp cloth and wipe the panel buttons on top inside of drawer.
5/19/2013 2:07:16 PM • Fisher and... • Answered on May 19, 2013
0answers
Door springs
Be the first to answer 5/7/2013 1:21:45 AM • Fisher and... • Posted on May 07, 2013Be the first to answer
Can not close the drawer
I think this problem has already been responded to.
1/27/2013 1:56:49 AM • Fisher and... • Answered on Jan 27, 2013
I installed the retrofit link arm kit and can not close the drawer
The lid seal actuator arms are very complicated to fit back in. It is likely the actuator motors are not set at release position when you fit the arms in. You may need to go into diagnotic mode and select Lid seal on. off function to ensure the both the motors are in release state before you fit the arms back. I am assuming you have a single drawer unit. Not sure why you mention "replaced seals in tub". The lid seal is a single plate.
1/27/2013 1:56:20 AM • Fisher and... • Answered on Jan 27, 2013
Door springs on Fisher &
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
8/25/2011 9:23:37 AM • Fisher and... • Answered on Aug 25, 2011
When we start our dishwasher it sounds fine you
water not circulating through pump..... check arms for blockeges... manually put water into wash chamber then start..... if this worked.. replace solenoid
2/28/2011 6:05:26 AM • Fisher and... • Answered on Feb 28, 2011
How do you remove the lower drawer?
Greetings,
The drawer sits on two slides. at the front of the bottom drawer. there are two tabs you push in while lifting up on the drawer. this will allow you to remove the drawer and set it aside. it will not come completely off without disconnecting the hose , but you can set it to the side to get to the electronics...
12/13/2010 1:07:31 AM • Fisher and... • Answered on Dec 13, 2010
2answers
2answers
Fisher and paykel nautilus. Cycle stalls with 15
OK, when you say it sounds like a record skipping does that mean its washing then not washing? what cycle are you using ? sorry to ask these questions but sounds like an unusual fault.is the water hot? could be control module or pressure switch fault. please reply and we can hopefully track down this fault.
6/4/2010 3:02:08 AM • Fisher and... • Answered on Jun 04, 2010
My unit does not have any power, it has power at
Hi
Thanks for using FixYa. Please check for the following if your dishwasher is not working--
1. Fuse (blown or tripped).
2. 120 VAC supply wiring connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board faulty.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
4/7/2010 10:11:20 PM • Fisher and... • Answered on Apr 07, 2010
Fisher and Paykel 24 in. DS603H SS Free-standing Dishwasher Logo
30 questions posted
Top Fisher and Paykel Dishwashers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Dishwashers
Most Popular Question
remove lower drawer
  • Dishwashers
